1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates?
Old Nov 4, 2002 | 07:12 AM
gregv's Avatar
Default 1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates?
hey guys
I am considering a set of ST 1" drop springs for my '91 Si hatch; first off, has anyone used a set of
these coils, and if so how were they? Secondly, will I need camber adjustment plates to compensate
for a 1" drop? I'll probably go with Koni reds because they are nice and cheap, and an Energy Suspension
bushing kit to replace the worn out factory stuff.
cheers
Old Nov 4, 2002 | 07:43 AM
JoshDM's Avatar
Default Re: 1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates? (gregv)
after you drop it take it to get an alignment done ($60.00) they will check your camber and make your decision after that
Old Nov 4, 2002 | 08:33 AM
keithv's Avatar
Default Re: 1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates? (JoshDM)
you probably won't need a camber adjustment kit, but do what JoshDM said above.
fyi, i lowered my integra 1.3" and didn't need a camber kit...but i just within spec. i took my wheels off the car yesterday to mount my snow tires and i do get a little bit of inside tire wear (about 1/16" more on the inside vs. the rest of the tire). this is on kumho ecsta 712s with 15k miles on them.
Old Nov 4, 2002 | 11:04 AM
gregv's Avatar
Default Re: 1" drop ST coils in a '91 Si hatch; do I need camber adjustment plates? (ridge racer 2)
thanks for the info guys
greg v
Creator
Jan 25, 2010 02:00 PM
CleanTeg
Suspension & Brakes
24
Jan 5, 2009 05:18 AM
dwarrick
May 11, 2006 10:20 AM
TegoDC5
15
Oct 20, 2004 10:01 AM
Blue10karat
Jan 5, 2004 10:28 PM
