Built B18c1 1200HP $4000
Old Apr 12, 2015 | 02:53 PM
KGP1's Avatar
Default Built B18c1 1200HP, JDM EG Stanley Headlights
92-95 JDM Stanley OEM Headlights off a hatchback. No broken tabs, no cracks, etc, great condition headlights, I'm including the PasswordJDM bulbs, and Also the Vision Technica amber corner lights, Driver side corner light tab is broken, I had used tape to hold it on (I had hit a raccoon, messed up my front bumper, fog lights, and driver corner light, Rest is good) Asking $150+Shipping, Pics below. I'm going to remove them from the car, and box when it quits raining. Then i'll take it to get shipping prices. Just give me zip code if you're interested so when I take it to get prices I can give you accurate price
Glue on stuff from the tape that was holding on my driver corner light..
Can see the spiderweb crack from a small rock or something in bottom left corner
This is where the driver side corner light is broken, Reason I had tape holding it on, I'm sure someone could easily reattach that with JB Weld or something if you wanted to reuse the corner lights, I was just throwing them in with the headlights because I won't be using them, Nothing broken on headlight, just corner light.
B18C1 motor for sale, Capable of 1200hp, Built to run on E85. Asking $4000 firm. Need money and it has to go. I got the receipts somewhere and there's over 8000 in the motor. It has never been ran, It is fully assembled besides the cams being degree'd in. I can include stock cams if wanted.
Located in Central Arkansas, Will have to be picked up currently.
.0020" on all rod bearings
.0015" on 1,2,4,5 and .0018" on 3, main bearings
.0019" upper ring gap
.0021" lower ring gap
.0040" p2w clearance
B18C1 Block
Darton Sleeved
ACL race bearings
CP pistons 9.8:1 compression 83mm w/ upgraded wrist pins
Brian Crower rods with ARP 625+ rod bolts
Micropolished/balanced crankshaft
ARP main studs
ARP Head studs
Moroso 5.5 quart baffled oil pan
Skunk2 magnetic drain plug
Cometic gasket kit
OEM Oil pump
OEM Water pump
Downstar oil pan,water pump, oil pump, rear main seal bolts
All OEM seals/gaskets
P72 Head
5 angle valve job
Ferrea Bronze valve guides
Ferrea high pressure seat locators
Ferrea valve seals
Brian Crower flat face stainless steel valves
Brian Crower dual valve springs
Brian Crower titanium retainers
Science Of Speed LMA's
Crower stage 3 drag/turbo cams
Skunk2 adjustable cam gears
Golden eagle 83mm head gasket
(Mission Critical Performance did all the head work (valve job bronze guides etc)
(Vibrant timing belt tensioner, hasport motor mount, etc not including, Longblock with sensors, water pipe, etc is included) If you question anything in pics if included just ask. Basically what's listed above in the description is what's included
Old Apr 15, 2015 | 04:44 PM
KGP1's Avatar
Default Re: Built B18c1 1200HP $4000
Bump, I added some JDM EG Headlights for sale
Old Apr 19, 2015 | 05:43 AM
Fliiip's Avatar
If my d-series does not work out, I will buy this... If you are willing to ship. Why didn't you ever run it?
dschybrid
Sep 25, 2013 06:40 PM
jdeacon
13
May 19, 2009 07:17 PM
CapnChunk
Apr 27, 2003 09:14 AM
fakemike
Oct 9, 2002 10:32 PM
