Prelude crank & tdc position sensors
Old Apr 11, 2015 | 07:31 AM
derfzog's Avatar
Default Prelude crank & tdc position sensors
There's write ups that explain how to use jdm or other obd1 motors in our obd2 cars , one of which is popular where you splice 4 different wires on pcm plug c to jump signal and eliminate the crank sensor. Unfortunately for luders, the tdc sensor is not in the distributor, so making the splices, simply jumps one dead wire to another dead wire.
The fix:
Simply swap the oil pump ober to your new block, retain all crank snout sprockets from odb2 motor, bolt in the two sensors, and away you go.
Never saw anywhere online where the prelude issue was specifically addressed so here it is.
Old Apr 13, 2015 | 07:55 PM
thirsk66's Avatar
Default Re: Prelude crank & tdc position sensors
This has been discussed many times and is in a bunch of threads on this forum. Just have to search and you will find this.
p1mmiz321
Aug 8, 2013 07:17 AM
akinas-crx
Oct 28, 2011 06:00 PM
chicows18
Jul 19, 2009 06:45 PM
oneprelude
Oct 6, 2008 07:35 PM
rhemu1
Jun 22, 2005 11:41 AM
