91 Honda Accord Cluster Reading Wrong !
Old Apr 9, 2015 | 07:33 PM
DomonicCB7's Avatar
Icon3 91 Honda Accord Cluster Reading Wrong !
I've noticed today that my cluster is reading wrong information ...
The gas suppose to be half and the speedometer jumps to 20 and then goes to 10 and stops there, while my RPM meter bounces at 2RPM .. and I haven't even started the car yet
I also noticed there was a spark in my starter motor ... could that be the problem why my cluster is reading wrong ?
I took it out today and nothing was burnt or jamming the needles everything moved fine !
please help.. first car an all.. kinda worried
Old Apr 9, 2015 | 07:38 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 91 Honda Accord Cluster Reading Wrong !
Might be a bad or loose ground.
Verify the harness ground at the thermostat housing is not corroded or damaged. Remove the bolt and verify the connection is clean underneath.
Verify engine mount ground bond cable is attached correctly.
Verify the battery connections are clean and tight, both at the battery and at the terminations.
Verify the battery is fully charged.
DomonicCB7
Sep 28, 2022 09:48 PM
bwindsor
Apr 29, 2013 06:19 AM
darkvision
Feb 15, 2010 11:51 AM
Givens
Jul 19, 2009 11:35 AM
Supremee
Feb 21, 2008 09:35 PM
