2000 GS Wont Start, see if you can follow my diagnosis!
Well I picked up a 2000 integra GS that wont start. The car is DUMPING fuel so much so that it was actually coming out of the throttle body. So i disconnected all the injectors, all which ohmed to 11.5 ohms. I put a noid light on the injector plugs and the light was BRIGHT super bright and not pulsing on steady. First thing i did was clean all the grounds on the car. Next it had an aftermarket alarm so i unplugged the mondule. All of a sudden i got a normal injector pulse so i put everything back together and tried to start it... Nothing. Next i checked for an injector pulse again and boom it was gone no pulse. I tried hooking up the scanner and it would not access the computer at all. Tried again and got in, got the code P1607 internal circuit A. Checked all the connectors to the ECM and they are clean. ECM is getting battery voltage as well. I think the car needs a computer, but i dont really work on these cars too much im just starting to get into them. What do you guys think?
buckeye honda
Jan 18, 2013 04:51 AM
marQues24
Nov 27, 2012 10:59 AM
xXFiendxx
20
Jan 2, 2007 08:30 PM
