ITR not vtech lobes specs
Old Nov 4, 2002 | 05:35 AM
paulITR's Avatar
Default ITR not vtec lobes specs
Like in the topic: does anyone know no vtec lobs specs?
I done search without result.
[Modified by paul ambra, 3:56 PM 11/4/2002]
[Modified by paul ambra, 4:02 PM 11/4/2002]
Old Nov 4, 2002 | 05:36 AM
Nameless RB26's Avatar
Default Re: ITR not vtech lobes specs (paul ambra)
har har har
Old Nov 4, 2002 | 06:12 AM
Nate B's Avatar
Default Re: ITR not vtech lobes specs (Nameless)
What are VTECH lobes?...I am not familiar with this so-called VTECH
Old Nov 4, 2002 | 06:25 AM
Chris N's Avatar
Edit: Nevermind.
[Modified by 1107, 3:28 PM 11/4/2002]
Old Nov 4, 2002 | 06:36 AM
DutchITR1689's Avatar
I think he means the low cam specs..
I don't know the exact specs. I only know it's around 4 and 6 mm lift and the primary cam is differenct than the secondary cam..
Old Nov 4, 2002 | 06:47 AM
paulITR's Avatar
Default Re: ITR not vtech lobes specs (1107)
Thanks to take time to answer and for your sarcasm.
Old Nov 4, 2002 | 07:14 AM
Nate B's Avatar
Sorry, It's Monday, I couldn't help myself. I believe if you check out http://www.itrsport.com you should find some good info over there. Josh put together a very good site on the ITR and it has tons of information.
Old Nov 4, 2002 | 10:20 AM
paulITR's Avatar
Default Re: ITR not vtec lobes specs (TypeR#1111)
Thanks, I checked the site (www.itrsport.com), it's nice, but doesn't contains any vtec cam specs.
Anyone else?
Old Nov 4, 2002 | 10:48 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ITR not vtec lobes specs (paul ambra)
I think you'd be better off in the regular integra forum, since everyone here has more knowledge about VTEC cams than non-vtec cams.
Old Nov 4, 2002 | 10:52 AM
Chris N's Avatar
Default Re: ITR not vtec lobes specs (Rguy)
He wants to know the cam lobe specs for the OTHER lobes on the b18c6 cam... not the cam that is activated at 5600 (i.e., when vtec engages). This IS an itr question and is itr related, so why go to the integra forum???
If someone has a helms, is that info in there? I do not have mine with me, and know no other way of obtaining that information while I'm at work. Maybe sgT or someone else might know this info.
Old Nov 4, 2002 | 11:02 AM
Rguy's Avatar
25 Year Member
Community Builder
Default Re: ITR not vtec lobes specs (1107)
ouch, so i misunderstood the question! And there is no other "cam that is activated at 5600" its still the same one as before 5600
Old Nov 4, 2002 | 11:03 AM
Nate B's Avatar
I believe he is reffering to the primary lobes
Old Nov 4, 2002 | 11:04 AM
1slowassr's Avatar
I didnt know that vtech was puttin cams in its phones these days thats pretty crazy man, how do they do that ****?
Old Nov 4, 2002 | 11:05 AM
Chris N's Avatar
So I made a mistake also. Primary lobes I guess is what I'm trying to say, thanks Nate.
So. What are the primary lobe specs on a b18c6??
[Modified by 1107, 12:05 PM 11/4/2002]
Old Nov 4, 2002 | 11:06 AM
paulITR's Avatar
a big to chris that cleared the question.
Come on with the answer now.
Old Nov 4, 2002 | 11:14 AM
skafia's Avatar
25 Year Member
Oh ****, he has a VTECH engine just like me!
Old Nov 4, 2002 | 11:16 AM
Chris N's Avatar
Default Re: ITR not vtec lobes specs (skafia)
Ok, I think we let him have it enough about the vtech. Nice way to treat our Italian members!
I searched and couldn't find the info. It is pretty accessible info, i'm surpised no one has it.
Old Nov 4, 2002 | 12:04 PM
Ricky Rojales's Avatar
I tried searching on google, but I can't find anything more than the VTEC lobe specs.
You've brought up a very interesting question, one I think most of us just take for granted.
Why are you inclined to know? Is it really that important?
Old Nov 4, 2002 | 12:07 PM
Chris N's Avatar
Default Re: ITR not vtec lobes specs (P)
I read some specs on the crower site, but not what paul is looking for.
Old Nov 4, 2002 | 12:17 PM
TurboITR's Avatar
here - these are itr cams...
PRI. Lobe
Advertised Duration Int/Exh - 215 / 219
Duration @ .050 Int/Exh - 178 / 180
Lobe Separation - 111 / 109
Gross Lift - 205/188
SEC. Lobe
Advertised Duration Int/Exh - 231 / 231
Duration @ .050 Int/Exh - 200 / 200
Gross Lift - 305/305
VTEC Lobe
Advertised Duration Int/Exh - 266 / 256
Duration @ .050 Int/Exh - 239 / 229
Lobe Separation - 107 / 108
Gross Lift - 459/416
[Modified by TurboITR, 4:18 PM 11/4/2002]
Old Nov 4, 2002 | 11:32 PM
gutmann's Avatar
Default Re: ITR not vtec lobes specs (B2FiNiTY+)
Oh, there are a very bad boys around
[Modified by gutmann, 8:34 AM 11/5/2002]
Old Nov 5, 2002 | 06:17 AM
sgT's Avatar
sgT
Default Re: ITR not vtec lobes specs (TurboITR)
PRI. Lobe
SEC. Lobe
VTEC Lobe
These numbers dont look right. look too large
Old Nov 5, 2002 | 06:24 AM
Chris N's Avatar
Default Re: ITR not vtec lobes specs (sgT)
They look like some crower cam info from their site.
Old Nov 5, 2002 | 10:51 PM
TurboITR's Avatar
crower website does not have itr cam - only ctr...
and i believe it is only vtec lobes - not pri. or sec. lobes
[Modified by TurboITR, 2:53 AM 11/6/2002]
Piro Fyre
May 22, 2011 08:59 PM
tranquillexer
Nov 17, 2002 01:59 PM
98Psi ITR
Feb 27, 2002 04:45 AM
