How much wear on the alternator belt is bad?
Old Apr 8, 2015 | 08:53 PM
paco_sinbad's Avatar
Default How much wear on the alternator belt is bad?
I just got a great deal on a car with a B16A3 and was checking the belts. My A/C compressor belt is nonexistent, and my alternator belt looks to have some wear of some sort on the edge nearest the motor. The car's throwing a CEL for the CKF, so I assume that somebody probably messed up the wiring and it got eaten by said alternator belt at some point. Tension is fine but I can see some obvious wear on the internal edge. Is the belt OK for now or should I replace it ASAP? I ordered a Helms manual. Can I replace all the outer belts easily in a normal garage? Clearance is pretty limited on that side.
Old Apr 8, 2015 | 10:15 PM
White_EG1's Avatar
Default Re: How much wear on the alternator belt is bad?
Does it squeal upon start up?
Old Apr 9, 2015 | 04:38 AM
Former User's Avatar
Yes, you can replace the belts in a garage.
...but diagnose the CKF issue first by removing the crank pulley and lower timing belt cover and inspecting not only the CKF but also the timing belt job. If the mechanic goofed up the CKF, then the timing belt may not be tensioned properly and the timing belt plate may not be installed in the proper orientation on the crankshaft. If so, bigger problems are in your future if you don't fix soon.
Old Apr 9, 2015 | 02:56 PM
tony_2018's Avatar
Fish Twig
Has a b16a3, but doesn't have the ckf?
OP you can at least post pics of the belts in question, WE DON'T SEE ANYTHING.
Also car information.
JasonST
Sep 6, 2013 10:02 AM
JMod
16
Jun 23, 2005 11:49 AM
Jet Black
Nov 9, 2003 12:11 PM
keithv
Aug 7, 2002 04:40 AM
Jason91CRX7
Jun 16, 2002 02:08 AM
