Honda S2000 Honda S2000
Idling high on it's own
Old Apr 8, 2015 | 08:07 AM
c-rex23's Avatar
Icon2 Idling high on it's own
I finally got a chance to start checking my car and RPM's were rising as high as 6k on idle. I cleaned iac and nothing. I did the map wack and nothing. I just checked my tps and on closed throttle it read 1.02 and on open it read 4.48. I see that the closed test is obviously way off but would the bad tps cause such a symptom? I am gonna buy a used throttle body this week.
Thanks
Old Apr 9, 2015 | 09:08 PM
A-Man's Avatar
Default Re: Idling high on it's own
maybe you have a vacumn leak?
Old Apr 10, 2015 | 08:29 AM
c-rex23's Avatar
I was thinking that but I could not find any plus the revs were getting so high, I couldn't leave the car on for too long. It's like if the gas pedal was being pressed by itself ( and no it's not the floor mats)
Old Apr 12, 2015 | 08:14 PM
A-Man's Avatar
if you have had the throttle body off maybe check the gasket isn't broken.
I don't know about the s2000 throttlebody but the D series and B series ones also have a opportunity to leak through the TPS sensor. so maybe it could an introduced problem.
Old Apr 13, 2015 | 10:52 PM
c-rex23's Avatar
I actually read about the gaskets on s2ki. I'm gonna be getting the new throttle body in 3 days with tps and map sensor. Will change all gaskets on sensors and throttle body and come back with results.
Old Apr 30, 2015 | 10:50 PM
c-rex23's Avatar
I solved the problem by replacing the throttle with tps sensor. That's for anyone with similar future problems
Old May 10, 2015 | 10:36 PM
gptoyz's Avatar
You mean you replaced the tps sensor on the throttle body?
crxb16a90
Nov 18, 2009 06:47 PM
aasaa666
Jun 29, 2008 08:13 PM
itsJDMyo
May 30, 2004 04:05 AM
asubennett
Sep 30, 2003 03:19 PM
