LMA's
Old Apr 7, 2015 | 09:30 AM
97CWITR's Avatar
Default LMA's
After 17 years my LMA's are ticking pretty good (adjusted the valves more than a few times).
I asked the dealership for the part number and said its 14820-p73-j01. These are the hydraulic type.
I was under the impression that these were discontinued and 14820-PCB-305 superseded these? (spring type)
Have seen many people recommend the spring type, but still confused on which ones to go with?
Thanks!
Old Apr 8, 2015 | 11:59 AM
white rocket's Avatar
Default Re: LMA's
OEM NSX LMA's. Spring type. I went that route with no complaints.
Old Apr 8, 2015 | 05:55 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: LMA's
PCB-305 is over $20 each. You can get the H22's PCB-003 for around $8 each and add hardened shims underneath to make them the right height.
The Great LMA Debate - Team Integra Forums - Team Integra
Also, Skunk2 makes a set of spring-style LMAs for around $100 (~$12.50 each).
Old Apr 9, 2015 | 06:00 PM
97CWITR's Avatar
Default Re: LMA's
Don't like the idea of having shims to save a few bucks. Leaning towards nsx lma's as they are an oem part. Looks like the nsx lma's are from the '91-93 engines?
Old Jan 5, 2018 | 02:39 PM
porofek's Avatar
10 Year Member
Default Re: LMA's
bumping an old thread instead of starting a new one. I'm thinking of replacing the LMAs on my B18C5 but the OEM R's are expensive ($27 - $45) and using the old hydraulic style. I'm thinking about going with the NSX ones like you did (14820-PCB-305) which seem to be the new spring type. I want to make sure these will fit fine on a B18C5 without any issues?
Old Jan 6, 2018 | 12:32 PM
Default Re: LMA's
I'd have to dig through some receipts to get the exact part number so I'll try to do that on Monday when I'm at work.
Old Jan 7, 2018 | 10:46 AM
Klasse's Avatar
Default Re: LMA's
https://honda-tech.com/forums/all-mo...312727/page12/ - Might be some useful info there
Old Jan 8, 2018 | 10:34 AM
Default Re: LMA's
Confirmed part number on my invoice from 2010 and it is the same number (14820-PCB-305). No issues at all so far.
Old Jan 8, 2018 | 01:45 PM
porofek's Avatar
10 Year Member
Default Re: LMA's
Awesome. Very much appreciated.
Old Jan 10, 2018 | 06:38 PM
94rs-turbo's Avatar
Default Re: LMA's
I have have for my NSX and ITR, same part need a set? pm me
S2BumpsticksGSR
Feb 24, 2013 09:03 AM
mario_pic
Apr 27, 2009 10:44 AM
IgnitionZ055
Suspension & Brakes
Feb 23, 2009 06:50 PM
gmrnguyen
Suspension & Brakes
Apr 26, 2007 05:18 PM
Osokwik
Mar 9, 2004 06:45 AM
