O2 sensor installation
Hi, I know this is on old thread but thought to ask. I was just working on replacing the oxygen sensor on my honda Civic 2001 EX and noticed after I took the upper sensor out that the tip of the sensor was way smaller than the new one! Does that matter? I purchased Bosch aftermarket and not sure what brand the old one is. It was rusted and black!
I thought to check about this first before I try to put the new one in. The new part is an exact fit to my honda according to Bosch.
Thanks
Thanks
Thanks for the info. I did install the new Bosch sensor and now my car is throwing P0420 code (catalyst system efficiency below threshold) for the first time! Is that why Bosch sensors don't work well on Hondas? Or am I looking at a new problem?
Thanks again.
Thanks again.
The code you have is generally caused by an exhaust leak ahead of or at the catalytic converter (often it's due to a hairline crack in the manifold where the primary O2 sensor screws in) or the catalytic converter itself is bad. Either way the catalytic converter generally needs to be replaced (if it's cracked you can try welding it, but it rarely works.
I pulled my original O2 in my exhaust mani the other day. I was expecting a fight so i got the engine "warm" spayed it down with PB Blaster and waited a while. Came back respray let soak again. After that it came right out with just an open ended wrench.
Denso or NGK FTW
Denso or NGK FTW
No, usually you'll just start throwing an O2 sensor code again prematurely or it will just keep throwing an O2 sensor code.
Thanks a lot for your feedback
Eduardo Escobar
Honda Civic (2001 - 2005)
Aug 10, 2017 01:19 PM
amej8
Jul 11, 2006 06:25 PM
so simple
Nov 24, 2004 10:54 AM
crxtreme27
Sep 19, 2002 02:01 PM
