Rattling from front end
Old Apr 6, 2015 | 05:46 PM
Ronnie23G's Avatar
Default Rattling from front end
Hey guys,
I've got a 96 Accord that has a rattling noise coming from somewhere in the front end. It only happens when the car is in gear, I'm pretty new to working on cars and can't really figure out where the noise is coming from, any help would be great.
Cheers
Old Apr 6, 2015 | 09:32 PM
lazlong's Avatar
Default Re: Rattling from front end
Are you just hearing it or are you feeling it in the steering wheel? or suspension? or Pedal(s)? Manual or auto transmission?
Can you post a video or sound bite?
Old Apr 7, 2015 | 12:25 AM
Ronnie23G's Avatar
Cannot feel the rattle.
Took the exhaust manifold heat shield off and it definitely decreased the severity of the noise. Could it be the exhaust heat shield further down also rattling?
Will post a sound clip tomorrow.
THanks
Old Apr 7, 2015 | 01:10 PM
lazlong's Avatar
It could be. Check all the heat shields to be sure. Also, those heat shields are important so, think about replacing the one you took off.
You could jack up the front end and listen while hitting the throttle. Be sure to use stands and not just the jack, that's just asking for trouble.
Old Apr 7, 2015 | 01:21 PM
95whitehatch's Avatar
The rattle is the symptom, you want to look for the problem. It could be loose or worn bolts on the shields. It could also be worn motor mounts.
I would have someone sit in the car with the foot on the brake and go through the gears- if you see the motor move excessively- check your mounts. This could be the issue- and what is causing the noticeable vibrations.
StraussBuster
Feb 16, 2013 08:23 PM
Nana16
Dec 30, 2011 05:12 AM
ck123
Oct 25, 2006 01:19 PM
Crosser
26
Jan 16, 2002 06:35 PM
