shiftlinkage cut and weld how much for b16a swap
hey i did a search.. just wondering how much i have to cut outta my shift linkage and weld for a b16a swap in an si crx.. some people say an inch some people say about 1.3 inches.
just wondering what everyone did?
thanks..
thanks..
Assuming that you are using a 90-91 Teg shift linkage, cut the following out of the straight section of the linkage:
Change rod: 2-5/8"
Compensation rod: 2-3/8"
Hope that helps!
Change rod: 2-5/8"
Hope that helps!
another tip : use a solid rod that fits in linkage, get a friend to hold the shifter in "neutral" while you mark it for welding MAKE SURE ITS STRAIGHT!
make sure the shifter boot is centered in the hole (dont ask me how i know)
after welding that's it
Happy Hybrids
Happy Hybrids
1 1/3 in is wayy too short...i cut mine 1 5/8's the first time...and it didnt come close to fitting...sucked..i paid 20 bucks!! but the next time i got another inch cut off...so both rods i got cut 2 5/8's inches....and it works fine...shifts smoothly
meagainsttheworld
Sep 25, 2006 07:27 PM
