My ongoing oil leak saga
Old Apr 4, 2015 | 12:57 PM
88CRX_SiR's Avatar
Default Oil pump issues
So I've determined that my oil leak is coming from my oil pump.
Got it off today and trying to replace the crank seal before I honda bond it and bolt it back on but the thing will not come out. I'm tearing it to pieces but it seems to be stuck on a metal "ring" on the pump.
Any ideas?
Old Apr 4, 2015 | 01:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: My ongoing oil leak saga
That's the front crank seal and I would hazard a guess that it was honda bonded in on the outside edge of seal.
You will have to keep working at it to get it out in pieces.
I don't see why there would ever be a need to add an insert for the outside portion of that seal. The sleeves are usually added onto the crank as that is what usually develops a groove over time.
I think that ring is just part of the seal construction. You can hook under it to help pull the seal out. Just try avoiding scratching any of the aluminum oil pump housing.
You could also try torching it. Burning up the rubber will cause it to contract as it burns and cracks. Could make getting it out much easier, and since the pump is out of the car, clean up will be simple and easy.
Here are the 92-95 oil pump pages:
Old Apr 4, 2015 | 02:19 PM
88CRX_SiR's Avatar
Thank you greatly!!!!
Old Apr 5, 2015 | 10:48 AM
Jimi Hondrix's Avatar
if you are still trying to work it out piece by piece a metal dental pick/cleaner works really well: 6 Piece Pick Set
CVS Pharmacy sells a set too.
Old Apr 5, 2015 | 03:17 PM
tony_2018's Avatar
Fish Twig
Dental pick is not strong enough. You need a seal puller tool for this.
1SickEG
Jan 28, 2013 03:54 PM
mattbatson
Mar 30, 2009 07:23 PM
NSTY Z33
Aug 4, 2004 10:55 PM
BlendedEJ8
May 31, 2003 11:22 AM
