88-91 Honda Civic/CRX and 90-93 Acura Integra Front Lower Control Arms are HERE!!!
J2 Engineering Front Lower Control Arms now available for the 88-91 Honda Civic/CRX and 90-93 Acura Integra ALSO with Spherical Bearings and dust boots:
$178.99 Shipped for Regular Polyurethane Bushings
$209.99 Shipped Spherical Bearing Bushings
These are not cast, they are CNC Machined from 6061 aircraft grade aluminum!!
J2 Engineering LCA's are made from certified T-6061 Aluminum and are designed as direct replacements with at least 3 lb. weight reduction over stock components (that is 3 pounds on each).
J2 specially redesigned this control arm to maximize its quality, so as to guarantee a "direct fit" suspension kit. With its reinforced bushing endlinks, the driver would have no reason to worry about the durability of these control arms. Along with the new Spherical Bearing, this control arm set would provide the vehicle with a new stability and control
