Noise from right rear interior
Old Nov 3, 2002 | 10:15 PM
EGTeK's Avatar
Default Noise from right rear interior
i stripped out all the seats and panels in the back and when im hitting some small bumps i hear some metal rattling noise from the right rear section. i checked to see if anything was loose but couldnt find anything. what could be vibrating?
im sure there is no loose change back there.
Old Nov 3, 2002 | 10:19 PM
bryant's Avatar
Default Re: Noise from right rear interior (92CXHB)
my rear glass somtimes makes that kind of noise.
Old Nov 6, 2002 | 08:13 AM
teal_dx's Avatar
I have a noise similar on my 92 dx hatch. it is coming from the passenger side rear. I replaced the main bushing w/ urethane one and all lugs are tight. shock tower bolt is also tight. I guess it could be the wheel bearing because it is starting to sound worn when i'm driving, but this metal clunk sounds alot like a loose wheel when i go over bumps... I have a new wheel bearing on the way, hopefully it will stop making the noise....
Old Nov 6, 2002 | 08:57 AM
nsxmatt's Avatar
Default Re: Noise from right rear interior (teal_dx)
If you have a aftermarket exhaust and your lowered, the control arm could be hitting the exhaust. Mine did when it was lowered a little more than usual.
Old Nov 6, 2002 | 09:01 AM
civicdohc's Avatar
it could be your wing in the back ontop the glass. thats what mines does. just letting you know what it might be
Old Nov 6, 2002 | 09:39 AM
splitime's Avatar
Default Re: Noise from right rear interior (civicdohc)
heh if its the wing i found a nice temp solution..... fold up a thin piece of cardboard...trident gum box.....and wedge it under the wing in the middle, stopped mine
knelson
Jul 20, 2011 11:26 PM
FlewByU352
Suspension & Brakes
11
Feb 2, 2011 08:36 PM
Red-Rag-B18
May 7, 2010 09:16 AM
SpoonFed
Feb 26, 2002 01:41 PM
