ABS delete questions
I read the thread on how to. I am confused on the brake line setup....
I have a 96 LS body, doing the delete but not sure if the rear brake lines and fittings are plug n play to the 4040 prop valve.
What is the easiest way to do the delete?
I am trying to keep the booster and master and just do the lines if possible.
I am looking at a diagram
46210-ST7-003
46310-ST7-A00
46320-ST7-A00
46321-ST7-A00
46330-SR3-N00
46340-SR3-N00
46360-SR3-A02
can i buy these and plug into the stock master cylinder ?
Can you supply a part number for booster and MC if i need a NON abs type?
Thanks!
46210-ST7-003
46310-ST7-A00
46320-ST7-A00
46321-ST7-A00
46330-SR3-N00
46340-SR3-N00
46360-SR3-A02
Thanks!
i'm doing this on my civic and have learned a couple of things. Your M/C will probably have a 10mm rear port and a 12mm front. You'll need an adapter for the front brake line. Brakequip BQ43 is what I got. This will allow you to use the non ABS line and the ABS M/C. Other than that, you should be good with just replacing the lines from the M/C to the prop valve, the prop valve itself, and the front lines. The rears should be the same, and will thread right in.
ORDERED and shipped on the way!
integrax97
May 3, 2007 12:15 PM
