intake gasket help
Old Mar 29, 2015 | 02:52 PM
Hawaiianhonda's Avatar
Default intake gasket help
Hey all. Running into problems with my 95 gsr that I'm installing a zerg thermal intake manifold gasket but wen I started her up, it reved all the way to 5k rpm and then back down and a slow fluctuation between idle to 4800ish RPN :'( please help
Old Mar 29, 2015 | 02:57 PM
B_Swapped93's Avatar
Default Re: intake gasket help
You have a major VAC leak, is every hose connected and did you scrape the old gasket off when you did this new one. 2nd the studs are very short how many threads are holding the bolts did you tighten then all, are you using a stock manifold or aftermarket one.
Old Mar 29, 2015 | 03:12 PM
The stock manifold and yes I noticed the threads were shorter but I tightened every but down as I've done this before on d series motors but this is my first attempt at a b series manifold but the wife is jus getting a stock one for me. All hoses were connected as well.
Old Mar 29, 2015 | 03:18 PM
5k is an insane VAC leak one that big you should be able to hear, spray some brake parts cleaner around the manifold flange when you find the leak he enine should stutter or die.
Old Mar 29, 2015 | 03:27 PM
I did that and nothing seemed to change so the wifey is out getting one from O'Reillys. Its jus dumb cuz I know covered everything u know :'( freaking frustrating.
Old Mar 29, 2015 | 03:39 PM
make sure you scrape the old one off, if it was still there it will look like paper/cork. If you couldn't fine one that big I would blame the gasket but for 5k that would have to be like the booster and every hose disconnected.
Old Mar 29, 2015 | 04:56 PM
Got her fixed Braddah man, the culprit was the stupid throttle body gasket. I got the zerg kit which has the plenum and throttle body gaskets but wen I swapped the throttle body gasket out, she purred fine. Jus was irritating cuz I literally pulled the manifold off 3 times :-( mahalos for ur help brotha
Old Mar 29, 2015 | 06:39 PM
never would have guessed that, lol should have said you changed 2 gaskets, either way glad you got it sorted .
SimplyCivic
Jul 7, 2015 12:10 AM
99GSRTurbo
Jan 2, 2007 04:17 PM
GsrVtec
Sep 13, 2006 09:53 AM
dc2turbo
Dec 13, 2004 05:33 PM
