91 Accord Manual Transmission Fluid problem
Old Mar 29, 2015 | 12:57 PM
Nimway90's Avatar
Default 91 Accord Manual Transmission Fluid problem
Hello everyone. I am having a major problem with my transmission grinding between every gear now. I had my clutch replaced 2 years ago and noticed a problem with it grinding into third recently so i decided to change the fluid in it. I could tell it was some sort of gear oil in it. I purchased Honda Manual transmission fluid and filled it up properly, jacked up the car to make it level and let it run out until its even with the hole. Started driving it around a bit and it didnt improve it what so ever. It grinds in every gear now so i stopped driving it completely. Any thoughts on the problem? I've heard gm synchromesh fluid is awesome.
Old Mar 29, 2015 | 01:37 PM
GoodUsername's Avatar
Default Re: 91 Accord Manual Transmission Fluid problem
Does your clutch pedal feel normal? This sounds like a clutch issue.
Old Mar 29, 2015 | 04:28 PM
Nimway90's Avatar
Clutch pedal is normal, nothing has changed
Old Mar 29, 2015 | 08:10 PM
AndyD's Avatar
Drain the trans oil again and refill. There is still some gear oil in it.
What I think is going on is the gear oil is too thick and it's not allowing the synchros to work properly.
I use Pennzoil 10w30 engine oil. 1.9 quarts.
1DwnyOG
Jul 26, 2018 01:39 AM
SIMATIC
May 4, 2011 04:58 AM
arielb1
Dec 12, 2009 01:34 PM
07galaxygrey4dr
Honda Civic (2006 - 2015)
21
Jul 27, 2007 10:12 AM
DC2_TEG
Aug 25, 2004 12:47 PM
