shifter linkage issues
Old Mar 29, 2015 | 09:30 AM
jdog_kustoms's Avatar
Default shifter linkage issues
my shifter is really sloppy and i found it to be the riviots on the joint ( what ever its called) by were it hooks to the tranny to be very sloppy is the d series and b series the same i have a 2000 civic ex with a si b16 engine and b16 tranny or is there a way to fix the worn out joint
Old Mar 29, 2015 | 12:36 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: shifter linkage issues
I believe there are bushing kits available for the joint, and no, B-Series and D-Series are different.
Old Mar 31, 2015 | 06:02 AM
jmo19d's Avatar
I had the same problem on my 2000 EM1. The bushing connected to the tranny was absolutely destroyed causing some pretty big movements during shifting. I replaced the bushings and it fixed the problem completely. My lower torque mounts and motor mounts were bad as well... you may want to check all of them out. I haven't replaced the motor mounts yet but the torque mounts really made another huge difference when I changed them.
blasterman87
Oct 23, 2009 05:45 PM
goldenhatch13
Transmission & Drivetrain
Aug 27, 2008 02:09 PM
themunchkinman
Apr 5, 2008 04:37 AM
manyakiexpi
Mar 16, 2006 12:25 PM
gulftiresinc
Jan 2, 2006 02:32 PM
