1996 accord wiring diagram?
I had a tire blow out (front left) yesterday that grabbed hold and ripped out the wiring harness under the wheel well from under the dash. I found the 13 pins 1 ground male hub for these wires but have no idea (except ground) which go where. It's a brown plastic clip... (Blinker, FL headlights, A/C, cooling fan, etc. Can anyone help? I completely appreciate it!
- tink
- tink
Sedan/Coupe Connector C309: 12-P Brn (Left kick panel)
1 – Grn ((-)Ground input to A/C condenser fan relay from ECM/PCM , heater control panel , or ECT fan switch A)
2 – Red/Yel ((+) Under-hood Fuse No. 19 to Left High Beam bulb)
3 – Red/Blu ((-) ECM/PCM A/C compressor clutch relay control)
4 – Blk/Yel ((+) Under-dash Fuse No. 8 to A/C compressor clutch relay)
5 – Wht ((+)Under-hood Fuse No. 34 to A/C condenser fan relay)
6 – Red/Blk ((+) Under-hood Fuse No. 32 to Left Front Side Marker bulb via combination light switch)
7 – Grn/Blu ((+)Under-hood Fuse No. 35 to Left Front Turn Signal bulb via Turn Signal/Hazard relay and Hazard switch)
8 – Yel/Wht ((+) Radiator Fan Control Module control to A/C condenser fan relay)
9 – Orn/Wht ((-) Ground G403 via dimmer relay to Left High Beam bulb)
10 – Red/Grn (+) Under-hood Fuse No. 19 to Left Low Beam bulb)
11 – Wht ((+)Under-hood Fuse No. 34 to A/C compressor clutch relay)
12 – Red/Blk ((+) Under-hood Fuse No. 32 to Left Front Parking Light bulb via combination light switch)
Alex E
Feb 4, 2014 10:21 PM
