Rear LCA question bushing.
Hey guys as you know the REAR ITR LCA has a different control arm than other hondas. The ITR does NOT use the shock bushing. I bought the master bushing kit but the rear bushings do not fit. So do you think i should get the hard race OEM replacement or should i get function 7s. Idk what to do because the ITR LCA seems beefier than the others.
Plus when you try to press the bushing out of the LCA on my ITR, it is f*king annoying because it messes up the actual LCA to, not bad but a little bit.
Opinions THans.
Opinions THans.
