1997 Civic EX speedometer issues
i recently just purchased a 1997 civic ex 2 door coupe and the speedometer has the issue of going to 10-20mph when i turn car on or start the engine, USUALLy this problem resolves itself after 2 minutes, but not always, sometimes i have to drive around for about 30 minutes or more to get it to zero out, then when it does it works just fine until i kill the engine again. has anyone had this issue or can tell me what it might be? i've unplugged the vss and the gauge still has this issue when disconnected. please help!
Thanks! Now my engine won't turn over good battery good alternator good starter power is there but starter solenoid doesn't even click and engine isn't getting power
I've had it do this to me 3 times now usually I can just try later and it turns over fine but now it won't do anything assuming its the ignition switch or loose cabling to it?
Also.. about your speedometer, I went through that this week. I was all ready to replace the speedometer based on all the research I found. Turns out it was the four screws that the speedometer is held into the cluster housing! Those screws actually power the speedometer. Take the cluster out and make sure those screws are touching the flexible circuit board (back of cluster) and are tightened down. After almost replacing mine with a new speedometer I find out it was just loose screws. Made sense after 19 years! Hope that helps ya!
ok so i jumped the battery directly to the starter, still wont pop the solenoid, checked for fraying and cleaned the ground and positive battery terminals like hell and checked the ignition fuses and the starter signal fuses. still wont even pop the solenoid, going to try and check the 12 to the solenoid itself and the park/netural switch if it's good im assuming it's either that switch or my actual ignition switch if i have a good 12v to the solenoid itself. if not it could just be the solenoid signal cable.
i'm assuming all this stuff and guessing, have no real experience with this stuff, also i have taken the starter, battery, and alternator for testing at autozone, no issues. ALSO checked fuse 15, it's fine, all fuses had 12v across both test points EXCEPT for the starter signal fuse which i assume only has power when the key is in the start position.
antman2x2
Honda Civic (2006 - 2015)
Jul 4, 2018 01:29 PM
jmwhonda
Jul 11, 2016 05:59 AM
