Timing Belt Help
Old Mar 24, 2015 | 08:42 PM
Jamm_95's Avatar
Default Timing Belt Help
Hey HT,
I'm having a problem lining up my timing belt, I have an H22a w/ the manual timing tensioner. I had the timing belt back on but after I started the car it made a tapping/ticking noise, so I turned off the car and a friend said that I was off by 1 tooth. So I'm trying to redo it and make sure I'm doing it right so I don't have to start over again. After I get the belt on and tension it, I turn the crank a few rotations I line the cams up again and check the crank pulley but the flywheel mark is off a little, and certain times between the cam gears there will be a little slack (shown in last pic). I'm trying to figure out if I'm doing it right and/or what should I do to fix it.
This is how it looks when I look at it normally, the cross is just a little lower down, only seeing the top of it,
The crank is lined up with the arrow
Cam gears are lined up
Slack in-between cam gears
If I look at it at a higher angle the cross lines up
Old Mar 26, 2015 | 08:03 PM
thirsk66's Avatar
Default Re: Timing Belt Help
Yeah so your off by 1 tooth at the crank fix it and your good to go.
Ef4doorwagon
17
Aug 30, 2014 11:58 PM
chromeBuddha
Aug 4, 2008 12:43 PM
SHG_EasyE
Mar 9, 2005 10:10 AM
Thrillhouse
Aug 9, 2004 02:47 PM
hitvtecgetloud09
Mar 21, 2004 05:27 PM
