Honda S2000 Honda S2000
Soft pedal after installing new clutch!
Old Mar 24, 2015 | 08:04 PM
s2000ap1's Avatar
Default Soft pedal after installing new clutch!
So I have a 2001 S2000 and I just put a SPEC stage 2 clutch in with OEM fly wheel. Problem is the clutch feels really soft. The gears go in but the clutch doesn't feel right. It's already been bleeded for air but still no difference?! What can it be?
Old Apr 2, 2015 | 02:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Soft petal after installing new clutch!
You either don't have the master cylinder set correctly...or its normal.
A new clutch will feel softer than a used clutch of the same type because the grease, springs, etc, are all new.
Old Apr 5, 2015 | 02:15 PM
DecepticonDc5's Avatar
Default Re: Soft pedal after installing new clutch!
Did you turn the flywheel to get the surface ready for a new clutch disk?
Do you notice any dead areas in the pedal? does it engage very low? Very high?
Do you know what type of clutch was in the car before you put this spec unit in?
intgrboy
Feb 16, 2009 10:54 AM
90teg
Aug 27, 2007 03:20 PM
fred92htch
Sep 10, 2004 05:36 AM
b20civic
Feb 1, 2003 07:38 PM
