Southern California Fresno & Below
View Poll Results: Which motor in a 95 Si?
LS?
0%
GSR?
0%
B20?
0%
B18C5?
33.33%
Screw it, leave the D...
0%
Sell that POS!!!
66.67%
Voters: 3. You may not vote on this poll
CA Emissions...
Old Mar 24, 2015 | 06:51 PM
SpeedRacerEX-R's Avatar
Default CA Emissions...
Will a B20 pass the reff? Is there a reason I shouldn't look at that swap? Otherwise, I'll just LS, but I'm looking for streetable power that is BAR legal.
Old Mar 25, 2015 | 06:11 AM
purgat0ry's Avatar
Default Re: CA Emissions...
I suggest you do some reading on what engines your legally able to swap in and still meet CARB/BAR/WTFEVER silly emissions laws CA has.
Old Mar 25, 2015 | 06:22 AM
Link?
Old Mar 25, 2015 | 06:45 AM
Former User's Avatar
Not trying to be rude, but did you try Google yet?
I did this search phrase "smog emission laws for california", and found this:
https://www.dmv.ca.gov/portal/dmv/detail/vr/smog
Another option would be to call or drive to the local emissions station and ask the tech some very specific questions. You're less prone to potentially flawed internet opinions taking this route.
Old Mar 25, 2015 | 02:13 PM
NotARaCist's Avatar
I never narc'd on nobody!
And considering how often the laws change...call the ref. Aside from that, this thread is quite literally an opinion poll. Use the FAQ sticky, and be glad that RonJ didn't lock your thread.
Old Mar 26, 2015 | 05:14 AM
purgat0ry's Avatar
As an example
This, last I knew the B20 was classified as a 'light truck motor' and thus wouldn't pass anything.
Old Mar 26, 2015 | 05:38 PM
MAD_MIKE's Avatar
MM Gruppe B
DMV site is junk, need to look at CARBs
Replacement Parts Guidelines - Aftermarket, Performance and Add-On Parts Regulations
Originally Posted by C.A.R.B.
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine.
If a B20 is from a SUV it is probably considered a 'truck' and is not allowed into a car.
BRIANxJDM
Jul 21, 2009 05:00 PM
Fliplm0de
Sep 20, 2006 03:35 PM
The Alchemist...
Oct 15, 2003 10:50 AM
souk
Jul 13, 2003 12:28 PM
