99 Civic with knocking motor
Old Mar 24, 2015 | 06:36 AM
Luisgil's Avatar
Default 99 Civic with knocking motor
in buying a 1999 Honda Civic dx with a knocking motor. It was off my friend and I have a bit of knowledge about cars so I bought it. Car runs and drives but the motor knocks on higher Rpms. It was ran without oil. Other than the high Rpm knocks the car runs decent. What should I replace or rebuild? Would it be the block or the head?
Old Mar 24, 2015 | 07:12 AM
tony_2018's Avatar
Fish Twig
Default re: 99 Civic with knocking motor
Budgeting?
Old Mar 24, 2015 | 07:13 AM
Luisgil's Avatar
There's definitley budgeting. I'm trying to spend the least money possible
Old Mar 24, 2015 | 07:18 AM
tony_2018's Avatar
Fish Twig
swap in a replacement. Make life easy, swap in the same engine but in good running condition.
Old Mar 24, 2015 | 07:19 AM
Luisgil's Avatar
Old Mar 24, 2015 | 07:23 AM
Luisgil's Avatar
Phone made me reply back. That's what I thought I would happen. The auto motor and manual motor have the same mounts ?
Old Mar 24, 2015 | 07:47 AM
tony_2018's Avatar
Fish Twig
Default Re: 99 Civic with knocking motor
Same mounts, but depending on the motor there might be some discrepancies with sensors.
Old Mar 24, 2015 | 07:52 AM
Luisgil's Avatar
It'll be another d16 y8 . Just comming From an automatic
Old Mar 24, 2015 | 08:48 AM
tony_2018's Avatar
Fish Twig
If your car is a 5spd than you'll have to swap the intake manifold because it uses a 2 wire iacv. ensure you replace the gasket becuase its going to be fucked up once you pull the manfold off. Make sure you clean it off completely.
Old Mar 24, 2015 | 03:15 PM
Luisgil's Avatar
Thats the kinda response I wanted
Anything else different?
Old Mar 24, 2015 | 04:03 PM
tony_2018's Avatar
Fish Twig
Yeah, do the maintenance while you have it out to safe yourself the headache.
Old Mar 24, 2015 | 05:16 PM
Luisgil's Avatar
Exactly what I was thinking. Timing belt job. What else?
Old Mar 24, 2015 | 06:41 PM
tony_2018's Avatar
Fish Twig
Any seals that can't be reached once its in the car.
Old Mar 24, 2015 | 06:49 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I find it the easiest to do the rear main, front main, oil pump, oil pan and valve seals along with the water pump, timing belt and tensioner (if needed) with the motor out of the car. The vtec, dizzy and cam seal all are prettty easy to do once motor is installed if they leak.
This will pretty much be all the major seals and will be a nice clean motor for ages to come.
That's my new philosophy when it comes to pulled motors.
Valve seals can be done with motor in the car and don't typically need replacing unless the guides need replacing so is overkill but hey....
squirrelysedan
Classic Hondas
Sep 25, 2017 12:29 AM
ne0tas
Nov 10, 2012 08:58 AM
Blazen_angles
Dec 20, 2007 07:43 PM
95vtechonda
Jul 11, 2006 01:38 PM
ocdcivic
Oct 24, 2003 11:24 AM
