Possible tdc problem.....
Old Mar 23, 2015 | 06:59 PM
Crystal82's Avatar
Default Possible tdc problem.....
I have a 94 civic with a 99 civic si b16a motor swap, obd1 wiring and ecm. Cel throwing code 8 top dead center sensor. My car still runs good, just a bit of a harder start than normal and no vtec. I have checked the coil, was good. Checked tdc sensor it was in spec. How do I test for a short in my wiring? Tia.
Old Mar 23, 2015 | 07:44 PM
Former User's Avatar
Default Re: Possible tdc problem.....
Short = continuity to body ground with a multimeter
Also test for a wire open
Open = wire lacks end to end continuity with a multimeter
Do all these tests from the 2 TDC sensor wire terminals in the ECU connector.
Old Mar 23, 2015 | 07:50 PM
Crystal82's Avatar
I understand. I was looking for the pints on dizzy plug and maybe ecm plug.
Old Mar 23, 2015 | 07:51 PM
Crystal82's Avatar
Meant pin outs
Old Mar 23, 2015 | 07:53 PM
Google search the 92-95 Civic service manual.
cksnah252
Oct 25, 2017 12:45 PM
lakahang
Apr 9, 2012 07:14 PM
JBirch_97Prelude
May 27, 2007 01:03 PM
salman
10
Jul 6, 2006 05:41 PM
EARLdaSQUIRREL
10
Sep 27, 2003 01:13 PM
