88si tranny on d16y8 motor
Now is this tranny good(88si)? whats the difference in 88, 89, & 90-91 Si trannys for a CRX. do they all perform the same and are they all equal strength trannys?
Will it bolt up to my d16y8? Whats the best clutch to get for it?
btw... I have a 90 CRX Si (mainshaft bearing is going on my tranny).. so i bought an 88si tranny entirely rebuilt by Honda with 1500k on it.
[Modified by PaImportTuner, 6:49 AM 11/4/2002]
i thought cable those were cable trannys for CRX's, and arent the 92-00 SOHC's hydro trannies? just what i herd from a friend with a CRX..... then on the other hand.... he doesnt know jack, but in his mind he knows all
im guessing the differance in the trannys if any would be gears, how short or long they would be
go with an ACT clutch
yeh but the flywheel and splines are different.. thats what im getting at, if i use the 88si tranny can i use my 90 clutch and flywheel?
Another option would be to use your 90 flywheel and pressure plate mated with a 86-89 accord clutch disk. The 86-89 accord uses a 212mm disk with a 21 spline input shaft. Hope this helps.
maybe i'm confused as its been a while since i looked at a flywheel, but doesn't the flywheel need to have the same spline count as the clutch?
The flywheel doesn't have splines, only the pilot bearing which is the same from 88-91. The pilot bearing accepts the end of the input shaft. The major difference in the flywheels is the amount of surface area for the clutch to mate to. That is why you alway want to use a flywheel and clutch from the same years.
I hope this clears things up.
ok my question now is?? which is better?? 90 flywheel with accord clutch kit or 88si flywheel and clutch kit.. which ones performs better etc..
I can't really say if one is better than the other. I will say this, Honda only offered the 190mm for one year. In 89 they bumped it to 200mm and then to 212mm in 90. They stayed with the 212mm clutch for the next 12 years. The 212mm disk should have more surface area than the 190mm unit. So I guess in "theory" the 212mm would be the best solution. That being said keep in mind that you don't want the accord clutch kit. All you need is the 86-89 accord clutch disk. You will still use the 90-91 civic/crx pressure plate and flywheel.
I heard I can use my 90 flywheel still, with a 88 clutch kit??? can I use my clutch disk AND pressure plate FROM an 88si??? I need to know cause im about to buy an 88si clutch kit????
you can use all 88si components (clutch, flywheel, pressure plate).
or you can go hybrid with the 90 flywheel and pressure plate with the 86-89 accord clutch.
ok now I'm going with the 90 pressure plate and flywheel W/89 accord disk.. so which throw out bearing & pilot bearing do i use for the 88 SI tranny, the same for the tranny??? I do need both pilot and throw out bearings right?? OR are both the same bearing?
[Modified by PaImportTuner, 2:09 AM 11/6/2002]
as for the pilot bearing, i would go with the 88si one, but i am not 100% sure on that. if you get the parts from honda, ask if you can return them free of charge if you end up needing the 89 accord one.
and the throwout bearing goes on the transmission where the pilot bearing goes on the flywheel.
you can see the pilot bearing in the center of the fywheel.
All the 88-91 civics/crx's use the same pilot bearing. I would imagine that they use the same throw out bearing as well. The parts guy should be able to confirm this though.
That's cool, I never knew the accord clutch disc had a 21 spline count! So with your setup ('90 pressure plate, accord disc, '90 flywheel) it will perform exactly like if you had the entire '90 clutch assembly!
Good luck! Y8 =
(if fuel/vtec is tuned properly)
Good luck! Y8 =
if you look closely at the part #'s on act's upgrade kit for the 88 the disc will match up to the 86-89 accord disc and the pp will match to the 90-91.. right now im runing this setup with a 90 flywheel..
MacneilBMX
Aug 15, 2004 07:02 PM
cornhusker
Jan 25, 2004 09:24 PM
Davanca
Aug 12, 2003 05:45 AM
