Lighting HID/Xenon kits, Retrofits and Associated Topics
2001 integra parking light issue
Old Mar 22, 2015 | 02:00 PM
98dxkoupe's Avatar
Default 2001 integra parking light issue
I'm having an issue with my passenger side parking light although the blinker does work but no parking light. Could this issue be a fuse or a short in a wire somewhere anyone else have this issue before? Thanks
Old Mar 24, 2015 | 03:19 AM
98dxkoupe's Avatar
Default Re: 2001 integra parking light issue
Anyone?
Old Mar 24, 2015 | 08:12 PM
LowTEC SaiMike's Avatar
This is happening to the 1157 that is on the turn signal correct ?
Old Mar 25, 2015 | 03:59 PM
98dxkoupe's Avatar
Yes the parking light and turn signal i believe is same bulb my turn signal works but no parking light on passenger side.
Old Apr 18, 2015 | 09:18 PM
98dxkoupe's Avatar
Any help?
Old Apr 19, 2015 | 10:31 AM
the 1157 is a dual filimant bulb . is both filimants not broken . Also , i think there is an 194 bulb as well . check both and see if the bulbs are broken
Old Apr 20, 2015 | 01:27 AM
98dxkoupe's Avatar
Bulbs are not broken first thing i replaced was the bulbs and still no passenger parking light i checked fuses and there good not sure whats going on
Old May 8, 2015 | 04:39 PM
98dxkoupe's Avatar
Anyone have a similar issue? Its driving me nuts!
Old May 12, 2015 | 02:55 PM
skillzx201's Avatar
you should check to see if the bulb holder is corroded.
Old May 12, 2015 | 03:55 PM
98dxkoupe's Avatar
I tried replacing the socket and still does the thing. Any help would be appreciated.
Old May 26, 2015 | 04:51 PM
98dxkoupe's Avatar
Bump still need help driving me insane having one parking light on! Replaced socket and still no parking light could there be a short somewhere?
Old May 27, 2015 | 06:08 PM
Hawaiianhonda's Avatar
For some dumb reason I'm having the same issue, passenger side running light doesn't work, I have a JDM front end thou but my headlights work but the fog and city light don't work
Old Jun 1, 2015 | 01:04 AM
98dxkoupe's Avatar
Its literally driving me crazy gonna see if i can trace the wires out
Old Jun 29, 2015 | 04:51 PM
98dxkoupe's Avatar
Bump anyone have this problem? Socket that i replaced was burned not sure if that means theres a short or a blown fuse?
Old Oct 11, 2015 | 07:16 PM
98dxkoupe's Avatar
Bump still can't figure this out passenger turn signal works but no parking light!!!
Old Oct 12, 2015 | 05:33 AM
rollinmyda's Avatar
I'm having the exact same issue on my civic. I have swapped bulb, socket, and probed the wire with a DMM. In my case I'm not getting voltage out of the fuse box on that wire so replacing the fuse box is my next step. Have you tried tracing the wire back through the harness and checking for continuity and voltage at each connection?
98dxkoupe
May 18, 2015 01:54 AM
Jimmy92Accord
Jul 23, 2008 09:51 PM
rayccfhk
Jan 17, 2008 01:28 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
niteboyzzz
Oct 4, 2002 11:24 PM
