Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
ECU/fuel pump/ac compressor,relay switch
Old Mar 22, 2015 | 11:39 AM
sixmnms's Avatar
Default ECU/fuel pump/ac compressor,relay switch
2007 Honda Pilot suddenly would not start, determined to be a fuel pump problem as it would start with the use of starting fluid. Several weeks later I have now replaced both the fuel pump and the main relay, fuel pump was still not running. Searching the internet I came across the idea of running a jumper wire directly to fuel pump. I have driven the car for 2 weeks this way now. However, I recently discovered that the air conditioner compressor, engine coolant fan and condenser fan are not working. The components are functional, but only if the relay switch is held open. These were all known to be working correctly before the original problem. Does this point to a problem with the ECU? If so, I have located one from a wrecked vehicle, but will it be necessary to have the dealer program the replacement ECU to my vehicle? Is there something else I should be checking before resorting to replacing the ECU?
Galan
May 21, 2011 03:55 AM
8OOSTED
Oct 13, 2010 03:54 PM
no_rice_please
Engine Management and Tuning
Oct 12, 2009 09:36 PM
krysted9354
20
Apr 8, 2009 03:32 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
