DA9 auto vs manual exhaust
Old Mar 20, 2015 | 07:11 PM
Daniel Hause's Avatar
Default DA9 auto vs manual exhaust
So I was looking around on rockauto, and I noticed an oem-ish exhaust the claimed to be for an automatic Integra only. Just wondering what the difference could be.
Old Mar 20, 2015 | 08:00 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: DA9 auto vs manual exhaust
Nothing.
The only exhaust difference is the extension piece that a 4 door has.
Old Mar 20, 2015 | 08:18 PM
rollinmyda's Avatar
90-91 and 92-93 header/cat/exhausts are also slightly different in length . Most aftermarket exhausts will require an extension piece to be used on 92-93. I'd be more worried about the model and year differences than auto vs manual transmission difference.
Old Mar 20, 2015 | 08:46 PM
B_Swapped93's Avatar
catback wise they're the same it's the exhaust manifold that see's the difference and the CAT.
Old Mar 20, 2015 | 09:25 PM
rollinmyda's Avatar
No, you're wrong.
"The 90-91 header is longer than the 92-93 header, the 90-91 cat is shorter than the 92-93 cat, and the 90-91 exhaust is shorter than the 92-93 exhaust. This means that if put a 92-93 header on your 90-91 teg simply getting a 92-93 exhaust will not make up the full length, you would also need a 92-93 cat." -Colin
G2IC - Catalytic Converter Length. 90-91 vs 92-93
markers
Honda Civic (2006 - 2015)
Jan 23, 2009 01:59 PM
Dumped DB2
Aug 13, 2004 04:38 PM
Hybrid2Be
Dec 18, 2003 07:33 PM
(__________)
Jan 20, 2003 02:13 AM
1997Accord
Aug 1, 2002 05:09 AM
