2000 LS idle issue. OBDII EACV test?
Old Mar 20, 2015 | 02:22 PM
burnoutboy's Avatar
The Credible Hulk
Default 2000 LS idle issue. OBDII EACV test?
Where's RonJ@HT with a fancy schematic or procedure page when you need him?
Long story kind of short:
Took a 120mi road trip on Monday with zero issues. Motor's been in for 9 months with no problems. After I got back and the car cooled down it now has a roaming/high idle (2500-3000 RPM) when cold only. Once it's warm it stays dead steady it about 600-750 RPM.
If I unplug the EACV when it's cold and bouncing the idle drops down to around 1K but it's a little bouncy (+- 250 RPM). If I remove the intake and plug both holes in the TB when warm the car dies as it should.
Should I just clean the EACV or is there something else I should be looking at?
I'm all for diagnosis over guessing.
Seems pretty well narrowed down to EACV related but I don't know the actual procedure.
Old Mar 20, 2015 | 02:44 PM
B_Swapped93's Avatar
Default Re: 2000 LS idle issue. OBDII EACV test?
over time they get gummed up but just 9 months i'm assuming you had it apart and cleaned it. That sounds like a vac leak 100% 2-3k idle is nuts and when there is a vac leak it will certainly roam as you're describing. have a good look at all the nipples/ports on the intake manifold see if something came loose and on the other end too. by that I mean at the booster but also where the line from the booster goes to the intake mani.
Old Mar 20, 2015 | 02:50 PM
burnoutboy's Avatar
The Credible Hulk
No vac leak. If it was it wouldn't die when I plugged both holes in the TB, and wouldn't idle normal when warm.
I DID test with a butane torch, (same idea as starter fluid) and removed/reinstalled all hoses in the vac system and checked for cracks/worn spots. I even checked the tb to intake mani for tightness and mani to head for the same.
I know they get gummed up but how would that cause this? Valve stuck open? I never did take it off and clean it when I did the swap. Donor car only had 75K on it. I mean it's no big deal to clean it but I'd rather test first if there's a way.
Old Mar 20, 2015 | 03:04 PM
the way you worded it your idle is at 2.5-3k...?
I won't post anything till that's confirmed, as that's why I said vac leak.
Old Mar 20, 2015 | 03:17 PM
burnoutboy's Avatar
The Credible Hulk
Originally Posted by burnoutboy
...(2500-3000 RPM) when cold only. Once it's warm it stays dead steady it about 600-750 RPM...
FWIW cold here is 30degrees, it snowed today LOL.
Cold idle is normally 2K on this car.
Old Mar 21, 2015 | 10:28 AM
burnoutboy's Avatar
The Credible Hulk
bump
I'm looking for a voltage or resistance test to test the EACV itself.
Old Mar 21, 2015 | 10:43 AM
turbohatch96y7's Avatar
PoSt a pic of your motor. Throttle body area and intake manifold area.
Is it on a chipped ecu or stock?
Timing spot on? Mechanical and electrical?
Wtf is a eacv?
Old Mar 21, 2015 | 10:47 AM
If youre talking about the idle air control valve you need to bench test it applying 12v to the iacv and obviously a neg. it should click open and closed. Check for it sticking in certain spots
Old Mar 21, 2015 | 11:34 AM
burnoutboy's Avatar
The Credible Hulk
Stock OBDII 2000 Integra B18B1 in a 92 CX running on a 1995 OBDI P75
Ran PERFECT for 9 months. Nothing was changed.
Wtf is a eacv?[/QUOTE]
Electronic Air Control Valve. Everybody calls it an IACV.... but.... ready?.... gonna blow your mind
Honda calls it an EACV it's the same thing. Different OBD terminology from what I understand.
Can you visually see the valve butterfly when looking in the two holes everybody cleans to see if it's closing all the way or just listen for the click, clean it if it clicks and cross my fingers??
Old Mar 21, 2015 | 11:52 AM
burnoutboy's Avatar
The Credible Hulk
NVRMND.
SO I go to take some pics and found something I never noticed before... because I wasn't expecting it.
I pulled this motor out of my mother in laws 2000 Integra LS. Her AUTO Integra LS.
In 2000 Auto tegs still have FITV. SO I plug bottom hole when cold and boom. Steady as fawk. Gonna remove, clean, and adjust FITV, if that doesn't help I'll find a manual FITV
Old Mar 21, 2015 | 11:55 AM
NVRMND. SO I go to take some pics and found something I never noticed before... because I wasn't expecting it. I pulled this motor out of my mother in laws 2000 Integra LS. Her AUTO Integra LS. In 2000 Auto tegs still have FITV. SO I plug bottom hole when cold and boom. Steady as fawk. Gonna remove and clean FITV, if that doesn't help I'll find a manual FITV
Thats exactly why i wanted to see pics.
I knew it wouldve been the fitv but didnt know if you had one. Pics are a billion words ******
Old Mar 21, 2015 | 12:02 PM
burnoutboy's Avatar
The Credible Hulk
LOL I hate your face.
I never even looked for it becasue I "KNOW" 96+ doesn't have FITV... who the **** drives automatics!
Old Mar 21, 2015 | 12:21 PM
If you did the swap the "eacv" and longer flywheel bolts shouldve told you so
Old Mar 21, 2015 | 12:31 PM
burnoutboy's Avatar
The Credible Hulk
Told me what? That it was an auto car? I think selling the auto trans off the parts car was my first clue of that LOL. Replaced the Flywheel bolts with ARP since I was buying PP bolts anyway.
The EACV is identical to the manual one sooooooo.... I'm guessing you're drinking today, that one made no sense even for you LOL.
I just had no clue auto's still retained a FITV after '96. I don't *** with autos LOL.
Old Mar 21, 2015 | 01:49 PM
The iacv isnt a 3 wire?
nitrojunk
Honda Civic (2001 - 2005)
Nov 4, 2013 10:20 AM
dlstech
32
May 31, 2013 09:57 PM
memorybox
Oct 8, 2009 02:26 PM
product
Feb 11, 2007 11:25 AM
