Technical questions for those of you running a Fmax turbo system.
How many thousand miles do you have on your turbo kit?
What is the turbine air ratio?
How is the downpipe, intercooler, and intercooler piping holding up?
The Fmax turbokit will support up to how much horsepower? (Assuming you have a fully built engine.)
Would you suggest getting the lower compression head gasket, or the MSD unit?
How are the additional fuel injectors holding up? How is the throttle plate/throttle body? I assume it gets darn filthy, since your dumping fuel right before it.
So far, has the kit been reliable?
Thanks for your reply.
EDIT: hehehe, I just noticed your location too, I am "somewhere in Korea" and you're "somewhere in MN" =P
[Modified by BlueShadow, 1:35 PM 11/4/2002]
There are alot of blown turbo H22's. Don't start down this path unless you really have alot of time, money, and energy to put into it.
we like to spin main bearings too. anyway the ringlands on H series is not all that so make sure its tuned right and has enough fuel. dont go over 7-8 psi.
TB doesn't get dirty at all. I ran on the extra injectors the entire time, but they are very difficult to run properly. I would never run those things again, or install them in anyone elses car. That goes the same for FMUs. If you go turbo, get a standalone, Hondata, AEM, Haltech, whatever and get it tuned properly, or even better, learn how to tune it yourself. If you're going to get the kit, order it without the MF2 and injectors.
That MF2 additional injector setup is a load of crap......Brian
if u cant affored a standalone fuel setup, u can always try the vafc hack. i just got my car runnin again a couple days ago, the vafc hack has made my car run so much better than when i had the mf2 setup with my fmax kit. also with the fmax, u cant run a t3/t4e without adding a spacer, i ditched mine and went with the new drag4, so far so good.
OMG.... am i imaginging things, or did BlueShadow just grace us with his presence?
he told me he forgot everything about turbo and Preludes
I'm gonna be getting back into cars now since I'll be coming back to CA in a few days. I am still deciding if I wanna try to get a 3rd Gen RX7 or a new 350Z, and in the end either one is gonna have either a bigger single turbo (RX7) or I will put one on there (350Z).
ragethemachine86
Jun 7, 2006 03:02 PM
gshockbreaker
Apr 24, 2002 11:09 AM
