sound like bad wheel bearing?
Old Mar 19, 2015 | 05:23 PM
ramboPandA's Avatar
Default sound like bad wheel bearing?
Driving on the freeway today my car started to make a noise. Like some rocks stuck in something and making noise. Car doesnt wobble either so no bent rim.
Old Mar 19, 2015 | 05:47 PM
B_Swapped93's Avatar
Default Re: sound like bad wheel bearing?
a wheel bearing on it's way out has a distinct howling noise. a video may help
Old Mar 19, 2015 | 06:05 PM
ramboPandA's Avatar
howling as in what? like try to explain it lol
Old Mar 19, 2015 | 06:18 PM
growling sort of noise there usually is wobble associated with it tho, what side is it coming from you didn't say and when does it come and go mph wise. how many miles on your car
Old Mar 19, 2015 | 06:35 PM
ramboPandA's Avatar
From the passenger side. It was all mph wise all the way until i stopped the car. And yeah i would say the noise is a grinding to. But when im going slow the sound is slow and when i go faster so the sound to. And car has medium high miles
also i got new rims, but they arent bent and they were fine before this happened. there are no vibrations like no steering wheel shake, so i dont think anything is bent. Its just the noise.
Old Mar 19, 2015 | 06:44 PM
ramboPandA's Avatar
bump
Old Mar 20, 2015 | 09:17 AM
cvcrcr99's Avatar
Does the noise stop when turning left or right?
Wheel bearing noise will sound as if you are in an airplane when traveling on the highway usually.
Old Mar 23, 2015 | 08:19 AM
andytheLSowner's Avatar
jack up the car then try to shake the wheel. if bearing is bad the wheel feels a little loose
Old Mar 23, 2015 | 08:41 AM
tamboo's Avatar
10 Year Member
if it's the rear you can diy fairly easily. you'll need a press for the front, make your own!
DIY Car Wheel Bearing Puller | Hackaday
i'd use steel pipe, that pvc looks too fragile imho...
bambbrose
Oct 11, 2015 08:01 AM
DannyGo
Oct 18, 2014 09:42 PM
Thomas Williams
Sep 8, 2012 05:28 PM
TEG98
Jun 20, 2005 01:54 PM
Rory Breaker
Mar 17, 2002 12:00 AM
