ITR Calipers
Old Mar 19, 2015 | 05:41 AM
widewhite's Avatar
Default ITR Calipers
OK guys I cant seem to find a thread on this so heres my question,
will 99' ITR calipers bolt right to my 94 knuckle/hub/rotor assembly for the front brakes..
thanks in advance for the info
Old Mar 19, 2015 | 05:56 AM
B_Swapped93's Avatar
Default Re: ITR Calipers
yes but you'll need the bigger 11'' rotor also and obv pads if yours didn't come with any. You'll love them couple them with an aggressive street pad like the hawk HP+ and you'll never look back.
Old Mar 19, 2015 | 06:13 AM
widewhite's Avatar
wouldn't happen to know if 11" rotor is 100% required or just heavily advised? if i'm not mistaken my rotors are the 10.3" does .7" really make cause an issue.
Old Mar 19, 2015 | 06:19 AM
Seriously? do you realize no one does that you'll be using 3/4 if not half your pad, vibration will be a factor also. Rotors are like $100 don't do something unsafe to save 100 bucks, I couldn't even find a thread where someone said they used a 10.3 with an itr caliper which should tell you something.
Old Mar 19, 2015 | 07:21 AM
Cobb2819's Avatar
'99 ITR was a 5 lug. While the caliper will bolt on, you'll need to find a 4x100 282mm rotor with a 64.1mm center bore. I think the only ones i've seen are from the UK for a MG or Rover. Fastbrakes might have something as well as far as a redrilled rotor goes.
Old Mar 19, 2015 | 08:21 AM
widewhite's Avatar
do you know where I can get 11" rotors that are 4 lug for my 94 integra ls
Cobb2819's Avatar
Old Mar 19, 2015 | 08:23 AM
Cobb2819's Avatar
Do you already have the calipers? I think you also need to mill part of the caliper bracket to clear the rotors.
Old Mar 19, 2015 | 08:34 AM
Ppl re drill prelude rotors all the time, or mini cooper rotors which are 4x100 to start. I can't speak on the notching the bracket as I have a 36mm 5 lug so it all bolted up.
Old Mar 19, 2015 | 12:20 PM
aw614's Avatar
10 Year Member
Loved
https://honda-tech.com/suspension-br...egras-3044628/
Old Mar 19, 2015 | 01:37 PM
Creator's Avatar
Check out mini cooper rotors, not exactly sure which model you should check but I know they are 4x100
Old Mar 19, 2015 | 03:25 PM
rollinmyda's Avatar
^ 07 base model mini
Old Mar 20, 2015 | 03:48 AM
widewhite's Avatar
yes I have the calipers already haven't done any test fitments yet, once I find a set of rotors ill check to see if it needs to be milled to fit the new rotors I get .
thanks
Old Mar 20, 2015 | 08:18 AM
Cobb2819's Avatar
07 Mini rotor is about 8mm too small, and the offset is wrong, but i might work because it's thinner than the ITR rotor. I still don't much love the idea of a rotor missing 8mm though.
Old Mar 20, 2015 | 12:10 PM
widewhite's Avatar
yea same here, I found on the brake upgrade chart that 95 prelude vtec model has a 282mm rotor only downfall is you have to re drill the stud holes for 4x100 wheels. and grind some of the bracket off the ITR caliper mounting spots. that's what i've gathered so far
Old Mar 20, 2015 | 12:47 PM
Cobb2819's Avatar
Fastbrakes 11" rotor, and all you need to do is grind down the bracket
Boilermaker1
Aug 19, 2007 01:20 PM
JG90CRX-Si
10
Jul 14, 2006 04:48 PM
555R
Aug 24, 2004 09:05 AM
euclid
Mar 28, 2003 04:17 PM
IN VTEC
Aug 20, 2001 10:21 PM
