no power to starter 99 civic ex
Old Mar 18, 2015 | 08:49 PM
eastcoastmenace's Avatar
Default no power to starter 99 civic ex
connected this wire to the starter with the other end touching the battery just to get power to the starter. the car started right up nd now i still trying to figure out how to fix the problem. looking to see if anybody might know a little bit about this.
Old Mar 18, 2015 | 09:28 PM
Former User's Avatar
Default Re: no power to starter 99 civic ex
Check rubber stopper at top of clutch pedal. Is it missing?
Old Mar 19, 2015 | 07:37 AM
the rubber stopers good everything else is good its just not getting power to the starter i think its called the s terminal.
Old Mar 19, 2015 | 07:46 AM
Test the ignition switch.
Old Mar 19, 2015 | 08:45 AM
that might be it im gonna have to check that out .
Old Mar 19, 2015 | 07:04 PM
I tested the ignition switch took the jumper wire i used before on the battery but this time i made it longer still connected to the solenoid to get to the ignition switch and touch the black and yellow wire and the car turned right on like nothing.
Old Mar 19, 2015 | 07:52 PM
1) Unplug the clutch interlock switch highest on the clutch pedal. With the key held in ON(III), check whether the Blk/Wht wire in the connector has battery voltage. This is the switch that the rubber stopper I mentioned earlier presses on when the clutch pedal is depressed. Are you sure the stopper is there?
Post results.
Old Mar 19, 2015 | 08:19 PM
slowpokesi's Avatar
I literraly just had this problem on my hatch. After pushing it up hill into my garage, came online found this exact same answer, sure enough the rubber plug was broken off. Wish i would of checked instead of messing up my back trying to push the car
Old Mar 19, 2015 | 08:28 PM
is this what you talking about ?
Old Mar 19, 2015 | 08:30 PM
Your car has a high one (interlock) and low one (cruise control). If that's the high one, then yes.
Old Mar 19, 2015 | 08:32 PM
the interlock is the one thats a little blurry in the picture
Old Mar 19, 2015 | 08:33 PM
slowpokesi's Avatar
The high one is busted. That's your problem. Unhook the cable and jump it with some copper and try it. I literally just had the same problem not even an hour ago. I guess thats what happens when the car turns 22!
Old Mar 19, 2015 | 08:36 PM
Nice vision. I'm blind.
Old Mar 19, 2015 | 08:45 PM
where do you see that its busted ?
Old Mar 19, 2015 | 09:04 PM
slowpokesi's Avatar
Old Mar 19, 2015 | 09:25 PM
tony_2018's Avatar
Fish Twig
Man these old blue ones suck *****, but I fear the new white ones will be the same regardless
Old Mar 20, 2015 | 09:43 AM
oh ok i see what you mean. so what part would that be that i need ?
Old Mar 20, 2015 | 09:46 AM
Move lower cruise control stopper to upper interlock switch position. Replace lower stopper when you hunger for cruise control.
Old Mar 20, 2015 | 10:03 AM
lol alright perfect ill give that a try thanks for the help guys really do appreciate it. ill post the results
Old Mar 20, 2015 | 11:47 AM
Would you know a easier way to getting that stop pad on. I tried it on my 15 min break but it was kinda tight space
Old Mar 20, 2015 | 08:08 PM
So i poped it in started up the car like nothing thanks for the help guys 👌
Old Mar 21, 2015 | 06:43 AM
austinramsay
Jun 16, 2014 09:16 AM
bge9198
Jan 18, 2012 07:43 PM
londoncrx
Dec 15, 2009 01:17 PM
KtHaNxBai
Jan 27, 2007 08:02 PM
Nisif
Nov 3, 2005 08:34 PM
