Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Need Help 2002 Honda civic 1.7l Coupe
Old Mar 14, 2015 | 01:33 PM
Dman84's Avatar
Default Need Help 2002 Honda civic 1.7l Coupe
It does not start
the battery tests good as well the starter is good took it out and tested it with battery spun just fine, when you turn the key its like I am using my spear which does not start it ether its just a door key and the starter does not even click at that point,kinda seems like my ignition is dead any thoughts ?
Old Mar 14, 2015 | 05:16 PM
Former User's Avatar
Default Re: Need Help 2002 Honda civic 1.7l Coupe
Test the ignition switch. Auto or manual transmission?
Old Mar 14, 2015 | 05:20 PM
Dman84's Avatar
its a manual
how would I test the ignition switch
Old Mar 14, 2015 | 05:22 PM
Originally Posted by Dman84
its a manual
There's a safety switch on the clutch pedal. Also test it.
Old Mar 14, 2015 | 05:26 PM
Old Mar 14, 2015 | 05:43 PM
Dman84's Avatar
ok ill have to do that tomorrow and let you know
Old Mar 15, 2015 | 04:15 PM
Dman84's Avatar
well got it going tested the clutch sensor everything good then went to test the ignition spot could not get any readings pluged it back in and car turned over so charged battery and car is going not sure why unplugging and plugging back in made it work but thanks
Woody.
Oct 7, 2011 07:06 AM
KleanEj1
13
Dec 30, 2009 02:43 PM
pinricky
Feb 4, 2006 02:54 PM
bamaTeg
Jan 13, 2003 08:04 AM
