93 Delsol Si intermittent no crank no start (solved)
So for the past 6 Months my 93 Del sol Si w/ a JDM D16A has randomly not wanted to start. It can go for weeks at a time starting in the 1st or 2nd try every time. Then 10 minutes later i will just get a clunk from the starter solenoid, the engine can be hot or cold its random. Sometimes 30x tries will yield nothing.
Only things that seem to make it worse are, rain/moisture, and strangely
enough parking on a hill. (though this just maybe in my head)
Fuel pump always primes
Hitting starter with hammer has no effect
Battery is new and batt Voltage is at 12.85V
Grounds are freshly cleaned and resistance at all grounds is 1.5 Ohms
Jumping the starter solenoid from the battery will not turn the car over, but will make the solenoid clunk. (When its acting up)
The car will turn over and start eventually if you try enough and runs fine (Minus a lumpy idle and bad MPG atm)
Everything is normal when going to start the car, untill when you turn the key to the cranking position. You just hear the solenoid clunk.
So my question is, is the starter the problem? Are there other tests i can do? I have a multimeter and an array of tools. I do not have a load tester.
P.S. i was going to rebuild my current one with Toyota parts but i instead spend the extra 15$ and got a warranty.
No not with a multimeter, i was under the impression if i jumped the starter from the battery and it still didn't crank, it pointed to the starter because new wiring didn't work either.
If there is a multimeter test i can do, i am more than willing. Im still slowly learning how to use it.
Next time try this --> Disconnect both the starter motor cable and solenoid wire from the starter. Jump (+) battery to the starter motor using a battery jumper cable. Next jump (+) battery with a separate wire to the solenoid. Does the starter crank every time you jump voltage to the solenoid?
Your test did not rule out an issue with the starter motor cable. The starter must receive voltage to both the starter motor and solenoid to crank the engine.
Ok thank you for clearing that up. One more thing when doing the test you mentioned, i run one wire to the solenoid wire and the other to where power normally runs to correct?
P.S. thank you for all the help. Much appreciated especially with all the newbs coming and shitt'n up the 92-00 Civic forum. You got your hands full.
Jump the solenoid using the 1 gauge cable at the starter.
You could use a 14 gauge wire or 16 gauge. Doesnt have to be jumper cables.
If you hear a click that alone tells you you have voltage at the starter and solenoid.
Dont make this harder than it has to be ron
Woah now shots fired....
I did RonJ's test today and the result was a consistently starting Delsol and a consistently happy me. I used a jumper cable from the positive battery to the starter, and some 1g stereo power wire clamped under the jumper cable for the solenoid (I couldnt fit 2 jumper cables). So i went ahead and did a few things \/
1. Replaced positive battery terminal with a new brass one. I cleaned up the wire ends and brushed them free of dirt and np2-c2 before i put on the new end.
2. Sanded the starter power connection, and all hardware.
3. Cleaned the solenoid connection with Qtips and alchohol.
4. Crimped the solenoid wire tighter.
And now it will start first try every time.
Thank you both of you for your help, I will update if the problem returns
Well that lasted half a day....
It works much better than before but the problems back to intermittent. I tore it back down and your jumper test still works every time.
Whats next? Replace the positive battery cable? Im running out of ideas, im trying to troubleshoot the clutch safety switch now.
What happens if you remove starter motor cable and then connect one end of the jumper cable to the starter motor terminal and the other to the starter terminal in the hood fuse box?
Well that lasted half a day.... It works much better than before but the problems back to intermittent. I tore it back down and your jumper test still works every time. Whats next? Replace the positive battery cable? Im running out of ideas, im trying to troubleshoot the clutch safety switch now.
You need a multimeter bra
Check ground path from starter body to batt neg
Check voltage from batt to solenoid positive input wire.
You might have a bad key switch
