hey guys are 88 starters different than 89-91?
Old Nov 3, 2002 | 06:06 PM
civbeater90's Avatar
Default hey guys are 88 starters different than 89-91?
just curious cuz im haing a problem starting the car and was wondering if the 88's are different?
Old Nov 3, 2002 | 06:28 PM
Urban Business
Guest
Posts: n/a
Default Re: hey guys are 88 starters different than 89-91? (civbeater90)
nope
Old Nov 3, 2002 | 06:55 PM
my_slow_civic's Avatar
Default Re: hey guys are 88 starters different than 89-91? (TorteX)
nope
Ditto
Old Nov 3, 2002 | 06:58 PM
Mugen Dom's Avatar
Default Re: hey guys are 88 starters different than 89-91? (sirk)
u guys are both WRONG dork hehe yeh the 88 has a nippon deso starter and is harder to ****** take on and off than the 89-91 mistuba starter wich has a different setup so teh rear bolt is more accessable trust me my family has a junkyard and we have at least 10 EDs sitting i have my 88 hatch and another 88 dx and teh starters from the 90 hatch was weird looking but fit mistuba
Old Nov 3, 2002 | 07:30 PM
Default Re: hey guys are 88 starters different than 89-91? (JdMB16Ahatch)
Le tme restate that then.
I pulled a starter from a 89 DX, and put it in my 90 si. My POS still starts.
Old Nov 4, 2002 | 07:22 AM
Mugen Dom's Avatar
well 90-91 have larger flywheels so the starters should be different
Old Nov 4, 2002 | 07:54 AM
wronghand's Avatar
According to the Majestic Honda website. The 88-91 all use the same starter. The have probably quit producing the 88 starters which probably were different. It seems as if everything is different on the 88's. Also, I think all of the flywheels are the same size. The difference is in the surface area that the clutch disk mates to.
Old Nov 4, 2002 | 11:20 AM
Hcivic88's Avatar
yeah, but this thread is asking if 88 are different from 89-91, and yes they are.
the 88's had the nippondenso starter and the 89-91 the mitsuba. i believe the nippondenso is more expensive too. I have an 88, and i have the nippondenso, trust me, theres quite a bit of difference in price
Old Nov 4, 2002 | 04:27 PM
Default Re: hey guys are 88 starters different than 89-91? (Hcivic88)
can anyone else verify that a 88 si strater will start a 89-91?
Old Nov 6, 2002 | 08:26 PM
wronghand's Avatar
Default Re: hey guys are 88 starters different than 89-91? (ridge racer 2)
Does this mean I can bolt my 88 std starter and flywheel to my 90 CRX SI trans and run it.
You can probably use the starter but not the flywheel. The 90-91 use a 212mm disk. Your 88 flywheel is designed for a 190mm disk.
Old Nov 6, 2002 | 08:40 PM
USDM 4G VTEC's Avatar
its like asking for alternator... there are nippon denso and mitsu... wich they both have the plug diff on the back.. but has same function and style.. i have seen a 88 DX starter being used on a 90 STD.... they both bolted right in...no problems so far,,,
braunzcrx
Mar 27, 2008 02:06 PM
wu tang
15
Jan 5, 2005 09:37 PM
DC2R714
Jan 3, 2003 03:25 PM
