Honda S2000 Honda S2000
Car not starting
Old Mar 11, 2015 | 08:43 AM
speedfreek128's Avatar
Icon2 Car not starting
When I turn the key all the lights/ radio come on. When I push the start button the starter isn't cranking. Looks like battery/ alternator are good. Trying to narrow down to if its the button itself or the starter. Was able to start with push start. Question is are the start buttons known for going bad?
Old Mar 11, 2015 | 09:22 AM
mistaanime's Avatar
Default Re: Car not starting
do you hear your fuel pump when you turn on the car before the start button?
those have a tendency to go out. I had mine replaced.
Old Mar 11, 2015 | 06:46 PM
Arsenal's Avatar
Hit the starter with a long metal pipe then try. Mine has been sticking lately - luckily being fixed under warranty as was recently replaced during the clutch job
Old Mar 12, 2015 | 08:31 AM
Tight-R's Avatar
It can be push started...
Old Mar 12, 2015 | 12:10 PM
MiasmaS2K's Avatar
I've never heard of the start button failing. Did you have the battery tested or are you just assuming? If the battery is good then check connections again and check your grounds. Also try what Arsenal said if you haven't already.
Old Mar 12, 2015 | 12:59 PM
Yes I can hear the fuel pump
Old Mar 12, 2015 | 01:04 PM
Checked fuses the manual listed and all good. I'm going to replace the battery since it is past warranty. Going to remove the starter and have it tested at Oreilly.
Old Mar 12, 2015 | 02:35 PM
Arsenal's Avatar
Did you try hitting the starter? Its a PITA to remove
Old Mar 13, 2015 | 07:49 AM
mistaanime's Avatar
lol you can't push start anything if your motor isn't getting fuel.
starter is in the back. don't break knock sensor when you are trying to bang it.
ATS*Mark
Oct 5, 2019 05:01 AM
Jlove1993
Feb 3, 2015 09:43 AM
inaety
Jun 24, 2011 12:57 AM
lawlss
15
Sep 14, 2009 10:23 PM
robble36
Oct 16, 2007 07:20 PM
