JRSC H22 guys, I need your help!
If you have a Jackson Racing supercharger mounted on your H22, I need some measurements please. I would like to know the farthest distance the s/c sticks out on the firewall side, and the farthest point the pulley/belt sticks out. I'm trying to see if I can use a JRSC for my H2B CRX. If you can help me, THANK YOU VERY MUCH.
Hi guys I have a big problem plz help...
I have a 92 h22a prelude and it's running rich and tends to misfire .. I checked the compression it's fine I change the TPS sensor with the map sensor and also the TB still misfiring. I have a hard time starting it in the morning. It idles hard before it warms up. The spark plugs are pitch black. My car is running on the stock h23 harness and I'm running p28 ecu I hit vtec that works the harness is a OBD0 and the engine is OBD1 maybe that may be the problem but not sure the check engine light is in its give off code 41 O2 sensor if someone can plz help me thanks!
