B18cr and stock ecu
Hey guys I've been searching this up but I couldn't find anything on it, if you find a link please post it.
I will be doing a swap on my em1, a 97 spec b18c type R, i will be running stock ecu for a while but I do plan on getting hondata s300. I know that I will have to convert to obd1 but I am not sure of I can use the jdm ecu since it is obd2a if I'm not mistaking.
What ecu can I run to make the most power?
needs to be a obd1 computer hence the converting to obd1. or find a ecu that has the obd2 connector but is obd1 on the inside so you don't have to run a jumper harness. I think ha motorsports has those. cheaper route is to buy a obd2-obd1 jumper and a p28 or converted p06.
I am thinking of running a p28 and a obd2b to obd1 converter harness, also I live in virginia and for some cars they do a diagnostics check for emissions.
I'm planning on keeping the jdm ecu , that way they can run the diagnostics with no problem.
Would this work?
I know I would have to disconnect the p28 and so forth.
Would this work?
No, you'll need a usdm obd2 ecu to guarantee that to work.
You'll need to make sure that everything is working correctly. Then for inspection, swap in the obd2 ecu a day or two before the inspection and/or make sure that you've completed the required drive cycle to set the readiness monitors.
Thank for all the help you guys, I heard I can run the stock b16a2 ecu and the engine will run fine.
If not I will have to find a usdm ecu that will work with inspection.
Probably won't run well enough to pass emissions if you have a sniff test, but might pass a plug in if you have everything hooked up correctly.
Why not find a usdm itr ecu and defeat the immobilizer? That's the correct way to do it.
I just passed emissions/inspection in NC with a stock LS p75 ecu and a 96' ITR swap in an em1. Just take it easy and drive like you've got some sense.
Drive 50-100 miles on the p75 to set the readiness monitors like stated above. After passing inspection, swap back to your JDM P73 ITR ecu.
There's alot of options out there, I don't really wanna go with the usdm itr ecu bc of the immobilizer. I won't have to get an inspection Until May 2016 .
But how do you like the swap in your em1? As far as power ,notice a lot of difference .
When comparing the B18C to the original B16A2, there is a noticeable power/tq gain for sure. However, the B18C still lacks in the torque department and that is what the heavy-ish EM1 chassis needs to "feel quick". I do have stock exhaust, intake, ecu, power steering and A/C for I plan to keep the car original as possible with the exception of a B18C longblock as opposed to a B16A2 longblock.
Immobilizer is not actually a problem.
Victory!!! finally i found a way to bypass immobilizer with OBD2 [Archive] - Honda Prelude Forum : Honda Prelude Forums
Doctronic - smart solutions
MaxxdoutSRT4_EK9
Jun 26, 2005 10:23 PM
kennyvb
Aug 25, 2004 02:19 PM
