Bent Frame
Old Mar 8, 2015 | 10:54 AM
haider99's Avatar
Default Bent Frame
Hello Guys, I am new to this forum.... i have been browsing for past few years, and finally decided to make a profile because I realy need your help. I am from Toronto, Canada and recently i bought this car from an auction and noticed that is frame damage in the rear end. Can't seem to figure out if it is actually bent. the trunk closes but i have to push it down with more force. And there is misalignment on top of the trunk.
I have not taken into a shop yet... will need to be towed.
Pictures at attached
Old Mar 17, 2015 | 07:23 AM
reinoFTW's Avatar
Default Re: Bent Frame
That happened to me once. I had to replace the lid and crash bar. I got lucky and I simply was able to bolt parts back up and get a good panel alignment. Seems as if the trunk latch was pushed
Most likely will need replaced..
Old Mar 29, 2015 | 09:45 AM
Hidenplanvew's Avatar
If you want to know if the frame is bent you need to measure in a big "x" shape at matching points. Looks more like the crash bar and truck lid need to be replaced, first then go from there.
~RareP3~
37
Dec 14, 2011 08:16 PM
ZXRider
Oct 20, 2008 08:50 AM
EF9*Hottie
Jul 6, 2007 03:34 PM
YEE*MagicEK20kombobomber
Mar 7, 2005 01:04 AM
Chris93Si
Jan 20, 2004 10:04 AM
