1999 EM1 fuel pump wont prime
Old Mar 8, 2015 | 06:45 AM
SPUNKYMUNKY's Avatar
Default 1999 EM1 fuel pump wont prime
i have a problem my fuel pump wont prime, relay is working as it should, all fuses are fine, it started one day i was driving an ran out of fuel, since then its started once or twice since then but cuts out after a min, now i cant get it to start atal? ive tried a friends pump also and no go? any ideas? thanks in advance
Old Mar 8, 2015 | 11:38 AM
Former User's Avatar
Default Re: 1999 EM1 fuel pump wont prime
Does the pump run if, in the main relay connector, you jump voltage from the fuse 44 or 13 terminal to the fuel pump terminal?
Old Mar 8, 2015 | 01:48 PM
where is fuse 44 located?? i ran a wire from battery straght to pump with a fuse and switch for temporary use, so that means the pump itself is fine? relay clicks as it should.. im baffled
Old Mar 8, 2015 | 01:51 PM
See FAQs sticky for fuse box diagrams.
Then do the tests I suggested.
Old Mar 27, 2015 | 06:10 AM
changed fuel pump, and resoldered main relay no difference
Old Mar 27, 2015 | 06:22 AM
Pay a mechanic to fix your car. You'll spend less money in the long run because replacing parts aimlessly rather than diagnosing will get expensive.
Old Mar 27, 2015 | 07:38 AM
tony_2018's Avatar
Fish Twig
You verified that the pump works by manually powering the pump, why replace it. Your issue could be a wiring from the fusebox or the mainrelay to the pump, or the main relay isn't receiving a signal from the ecu. Troubleshooting is the only way.
Old Mar 27, 2015 | 07:43 AM
I had a good one spare i just said id try anyways, so what do you mean will i run wire from pump to the fuse 13, then see does it prime itself or what? i cant afford to bring to mechanic unfortunately
Old Mar 27, 2015 | 08:04 AM
turbohatch96y7's Avatar
So you have a multimeter?
Old Mar 27, 2015 | 08:07 AM
no unfortunately someone stole it :/ i must try get another
Old Mar 27, 2015 | 08:14 AM
tony_2018's Avatar
Fish Twig
Suggest now would be a good time to buy one.
Old Mar 27, 2015 | 03:58 PM
joey1320's Avatar
You can get a free dvom at harbor freight. Get one and learn how to diagnose your car.
You can download the Honda service manual online and have access to factory diagnosis charts.
This is from Ron's photobucket page -http://s639.photobucket.com/user/RonJ_HT/media/picture_5582.jpg.html
Scarekrow
Oct 11, 2015 08:05 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
snzh22
Aug 8, 2007 04:53 PM
bb4socal
Feb 11, 2006 06:22 PM
