Need help pulling CEL codes
Old Mar 7, 2015 | 11:39 PM
alohadaily's Avatar
Default Need help pulling CEL codes
I have a JDM B16A in a 2000 EK Coupe, EX model fyi.
Check engine light has been on for a month now.
I've tried jumping the wires to see what its throwing, it didn't work.
Also used a OBD2 code reader and it still doesn't work.
By the looks of it, who ever did the swap used the d-series harness.
Not too sure if it's possible to use a d series harness for a b series because all of the swaps i've been a part of we just buy a new rywire harness.
Old Mar 8, 2015 | 12:29 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Need help pulling CEL codes
exactly what wires are you jumping?
There's no reason NOT to just use the original harness when doing a B swap.
Old Mar 8, 2015 | 05:07 AM
alohadaily's Avatar
The 2 pin connector plug next to the ECU.
I usually just get a brand new harness just in cause things break, but its a OBD2a harness on a OBD1 engine.
Old Mar 8, 2015 | 05:25 AM
r_Senik's Avatar
bet it has an obd1 ecu in it.
but the "paper clip" method should've worked.
Old Mar 8, 2015 | 06:44 PM
alohadaily's Avatar
It has a 2000 SI ECU right now.
Old Mar 9, 2015 | 12:30 PM
Former User's Avatar
The ECU may be bad.
1dopesi
Apr 2, 2011 01:19 AM
T3X
Nov 13, 2009 06:21 PM
kcvi3tstyl3
Apr 20, 2009 06:17 PM
jdmdikk
Apr 15, 2009 07:55 AM
deluzracerx
Jun 18, 2005 07:51 AM
