so I'm swapping d16y7 back into my 98 cx hatch m/t. The issue I'm running into is that the evap plugin on the harness isn't in the correct location. The original harness had it right across from where the main ground is on the begining of the harness. The new harness didn't have it there instead its up by the intake manifold. Do I have to extend the plug wires to make it reach the evap canister? Is it the same wires running back to the ecu? Thanks for the help.
