Engine code 45 too rich/too lean
Need some help from anyone who's delt with this code.
I'm getting poor mileage, occasional idle drop to 400rpms, power delivery isn't smooth.
Last thing I want to do is throw parts at it.
Anyone recommend tests to run or what could be causing it?
Some other threads suggest a fpr, o2 sensors...
I believe the sensors are fairly new but could be faulty. An oem fpr used is only $20...
Help or suggestions welcome!
Check your mech timing.
If your idle drops try cleaning the IACV with brake cleaner.
Check for codes first like mention above.
P0171 (45) is system too lean probable cause:
Fuel system
Primary HO2S (sensor 1)
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
P0172 (45) is system too rich probable cause:
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Only difference from is exhaust leak.
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Fuel system
Map sensor
Contaminated fuel
Valve clearance
Exhaust leakage
Fuel system
Map sensor
Contaminated fuel
Valve clearance
It was P0172 too rich.
Have it at Acura now and the fuel system is okay, same with O2 sensors.
Getting a valve adjustment next week. Will keep this thread updated so future ppl will have an idea.
How long (time wise) are timing belts good for?
Last replacement was 12 years ago but only 50,000 kms.
