Best mod for under 500$
Old Nov 3, 2002 | 04:50 PM
Ladysman_civic's Avatar
Default Best mod for under 500$
Ok so i have a 96 EX civic... what would be the best mod for under 500$ I would like a good horsepower gain though.. Thanx
Old Nov 3, 2002 | 04:53 PM
Eee Pee's Avatar
Default Re: Best mod for under 500$ (Ladysman_civic)
Tires #1
Intake & Header #2
Stripping interior (real #1)
IMO of course.
Old Nov 3, 2002 | 04:55 PM
PolosportZ81's Avatar
New User
Default Re: Best mod for under 500$ (E Prep)
nitrous
Old Nov 3, 2002 | 04:58 PM
kmf0211's Avatar
BEST mod even though you said you want a Horsepower gain - IMO it would be coilovers or a good suspension set up...If you have any money left Id look into an AEM CAI or an Exhaust.
Old Nov 3, 2002 | 05:01 PM
97hb's Avatar
Default Re: Best mod for under 500$ (PolosportZ81)
nitrous
I got my kit used for $350. Best bang for the buck, besides weight reduction(my favorite mod ).
Old Nov 3, 2002 | 05:03 PM
Default Re: Best mod for under 500$ (97hb)
what kinda of weight reduction would you recommend?
Old Nov 3, 2002 | 05:04 PM
jas0n's Avatar
Please don't hurt me!
nitrous for $500 will give you the most hp
Old Nov 3, 2002 | 05:06 PM
mooseknuckle's Avatar
Default Re: Best mod for under 500$ (couter)
nossssss y0
Old Nov 3, 2002 | 05:07 PM
seano's Avatar
Koni yellow adjustables
They will make your car drive soooooo much nicer, it's one of those mods that after dropping all that money on you never regret. You can get some Koni's before you ever change out your springs, but don't get springs until you have upgraded shocks.
I realize that you asked about hp upgrading mods, but overall you will be happier with suspension mods at first. You use extra power occasionally, but you will ALWAYS be using your suspension. My Si's engine is comepletly stock, and I am going to build up the suspension before I even bother going faster because my speed is more limited by what my suspension can handle confidently than anything else. There is nothing like confidently taking turns, and having a car that responds to input very fluidly, and being very stable at high speeds, I was surprised how much my car "sticks" on the highway, it used to feel kinda floaty at high speeds before suspension mods. in fact it will make your car quicker because you don't have to slow down has much to take turns and stuff.
I am personally planning on my next mod to be a LSD, but you should consider a swap before you start doing mods like that. In fact, if you build up your suspension first, by the time you have that done, you will want a swap. Ya, you might want to run out and drop $500 on some mod that will give you a couple (would barely make a difference) of hp, but that money will make a larger performance increase if it goes into suspension.
cliff notes: You can have MUCh better road feel, less lean, more traction, better highway stability and with the Koni Yellows you can actually have this WITH a MORE comfortable ride than stock.
Or you can have 5hp that you probally won't even notice, except your car will be louder.
Old Nov 3, 2002 | 05:23 PM
VTEC-DA's Avatar
Look in your car. You see the steering wheel, shifter and drivers seat? Take everything that isnt those items out. That is weight reduction.
Old Nov 3, 2002 | 05:34 PM
madtownhonda's Avatar
nitrous
Old Nov 3, 2002 | 05:43 PM
idreamsi's Avatar
Default Re: Best mod for under 500$ (madtownhonda)
speaking of nitrous I have a Zex kit right now for $350 shipped. Everything included rready to go. Let me know if you are interested. Need the money.
Old Nov 3, 2002 | 06:19 PM
. o 69 o .'s Avatar
Default Re: Best mod for under 500$ (idreamsi)
Z-10 radius rods.
Old Nov 3, 2002 | 06:21 PM
ncrx1's Avatar
Default Re: Best mod for under 500$ (B16B)
srr 4.9 final drive
http://www.aj-racing.com
Old Nov 3, 2002 | 06:22 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Best mod for under 500$ (ncrx1)
nitrous
Old Nov 3, 2002 | 06:46 PM
Zenki James's Avatar
Default Re: Best mod for under 500$ (Emerica)
used NOS kit
rear tie bar
-James
Old Nov 3, 2002 | 07:11 PM
Nameless RB26's Avatar
srr 4.9 final drive
I'd do that without a doubt.
But I would also want some suspension upgrade too.
Old Nov 3, 2002 | 07:51 PM
bretx0r's Avatar
Default Re: Best mod for under 500$ (seano)
for sure. konis rule
Old Nov 3, 2002 | 07:55 PM
Plan B's Avatar
Default Re: Best mod for under 500$ (Hatch_92)
wishes this was the first $500 i spent on my car.
Old Nov 4, 2002 | 01:42 AM
D16Z6racing's Avatar
Default Re: Best mod for under 500$ (Plan B)
I'm assuming this will be the first mod to the car? Be sure you know whta you're doing too. Speed/power don't mean a thing. You said you wanted horsepower for under $500 right? So how are you gonna handle that power in the turn coming up in the road? How ya gonna stop in a tight situation?
Speed and power don't mean a thing if ya can't handle the turns or stop in time.
1st) Susepsion/Handling.....IMO
2nd) Braking.....IMO
3rd) Safety (of some kind).....IMO
4th) Power.....IMO
Old Nov 4, 2002 | 01:54 AM
EddieHatchBlack's Avatar
for just pure speed, w/ 500 and good driving, i'd say nitrous oxide. but if its a mod in general, i'd say suspension.
Old Nov 4, 2002 | 02:34 AM
97hb's Avatar
Default Re: Best mod for under 500$ (buster13)
4th) Power.....IMO
1st) POWER
2nd) Suspension
3rd) Brakes
4th) Weight Reduction
5th) Rice (your option of course)
Huh, different points of view
Old Nov 4, 2002 | 02:44 AM
I can see putting power as 1st for certain types of power; intake, header, exhaust, ignition, etc.
But not a major source of power. I still think you need to know how to handle your car in every situation before you give a power plant to someone. And only a few post, I assume a newbie, if not, my apologies, I would never suggest nitrous for the 1st mod.
Old Nov 4, 2002 | 02:52 AM
97hb's Avatar
Neither would I, unless you had experience with it before hand .
Old Nov 4, 2002 | 06:04 AM
v00tecsi's Avatar
Suspension for sure!!!!
