Manual window is hard to roll up & down.
On the driver side it's fine but on the passenger side, my windows are so hard to roll up and down. Anyone know how to fix it? I took out the door panels and sprayed WD-40 in it but the problem is still there. Any help is appreciated.
Yeah, my driver side is good and passenger side is bad. Damn passangers slammin my door
. Anyways on my car I found that the bracket that the window actually slides on is bent. I bent it back as good as I could and sprayed graphite silcone spray and has been smooth ever since
take off the door panels and spray silicone lubricant on the rails.
Or lifts some weights!?
You need a new window regulator arm.
For what car is this? I'm look at http://www.hondaautomotiveparts.com and I see it for ~$13.00
Go check it out.
Go check it out.
I'm guessing this.
REGULATOR ASSY., R. FR. DOOR (MANUAL) 49.63
check here: http://www.hondaautomotiveparts.com/...y5=DOOR+WINDOW
Try to re-align the window first. There is a bolt that would be near your elbow when you are seated. It has a small range of adjustment for tilting the window.
It's behind all the door crap on the sheet metal.
out_of_order
16
Jul 26, 2004 10:06 PM
RATEDR
May 23, 2002 06:39 AM
