Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Transmission problems
Old Mar 4, 2015 | 04:25 PM
VicMaldonado21's Avatar
Post Transmission problems
For a short period of time now when I shift from Park to Drive or Park to Reverse my Civic sort of jolts forward and this only happens when I shift from Park to Drive or Reverse. The car shifts fine when I am driving, all my other gears work good. Occasionally when I **** into drive the indicator of what gear i am in on the dashboard P D N R D2 it will say it is in Neutral or nothing will be highlighted but if I jiggle the shifter or go from Park to Drive it illuminates. Has anyone ever experienced this or has some solutions as to what causes these issues?
Old Mar 4, 2015 | 07:36 PM
Former User's Avatar
Default Re: Transmission problems
You'll get a jolt if the idle speed is high, such as on a cold morning. That's normal.
But you need to adjust the shift cable or gear switch in the console.
Old Mar 6, 2015 | 06:32 PM
Thank you so much for that information. By any chance did you get that information from the Haynes book?
Old Mar 7, 2015 | 10:34 AM
So i tried to do these adjustments but the car is still doing the same thing. unfortunately i couldn't find this positioning hole that the instructions were talking about
Old Mar 9, 2015 | 02:48 PM
bump
where can i locate the gear switch?
Old Mar 11, 2015 | 01:15 PM
s0hayat's Avatar
Well than you have to adjust the gear switch if you remove your front passanger side wheel you will see that switch which is covered with black plastic cover. This issue is already covered if you look up the transmission issues you will come across that thread and will tell exactly how this is done. Hope this helps.
old-sk0ol
Sep 3, 2014 09:39 AM
Shannon Sampson
Dec 4, 2012 09:19 AM
'95 BA8
Jun 18, 2010 06:46 AM
Soltis
Acura TL, RL & ZDX
May 26, 2010 08:56 PM
SOHCMAN
Nov 25, 2002 02:49 PM
